Old 07-03-2007, 11:34 AM   #1
71cheyennezz4
71cheyennezz4's Avatar
Electrical Problem
Im having some weird electrical problems, every so often when im driving i seem to loose all voltage to the truck it will start running like hell and you can tell its not getting 12 volts to the distributer, also every once in a while when you shut the truck off, everything will be gone and you have to wait a while or just get lucky and suddenly power will return, ive got it narowed down to where it could be but everything checks out, i.e positive starter wire ect. any ideas?
71cheyennezz4 is offline   Reply With Quote
Old 07-03-2007, 12:54 PM   #2
cdowns
cdowns's Avatar
Re: Electrical Problem
completly remove both battery cables from the truck and clean the battery terminals next clean all 4ends of the battery cables and clean to brite metal the spot on the frame and on the engine block where the grounds go reassemble and test
looking to see them is not the same as cleaning and installing them
Old 07-03-2007, 02:38 PM   #3
OLDIRON69
I agree with cdowns, I had the same issue, it was a ground problem. There was initally a ground strap there, I just missed it when I put the first engine in the truck. I went to start it up and move it and nothing! I had just drove 15 miles home and ran fine...bolted the ground strap down and FIXED!
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 07-03-2007, 02:50 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
where the little wire from the positive wire goes, that little junction block, pay close attention to that too. That point is where your whole truck picks up power from.
Old 07-03-2007, 03:49 PM   #5
kwmech
Unplug the ignition switch from behind the dash and have a look at the connection------- could be melted
Old 07-03-2007, 05:50 PM   #6
stsalvage
Scrapper 1
stsalvage's Avatar
well I've seen this a few times and the battery can really couse that problem but in 1950--1966 chevy trucks the Horn Relay controls all the power in the truck i will show a picture of it the one power wire that gose to the Horn Relay Gives power to the Fuse panle that's where you get your parking lights head lights and dash power even before you turn the Key switch when the truck is not running even thow the Key must me on to work the wiper motor and some Radios the Key switch hets it power from the purple wire that come off the starter. If you look most truck will have a wire running for the battiey post to the drivers side of the truck and it gose into the fuse panle.Now i say buy a extra Horn Relay switch cus if your stuck out in the middle of no where you pretty stuck .You can EDIT rig it and hook them aall to gather but chances are them smaller wattage wires will not like the 12 Volts and then you have a fire
stsalvage is offline   Reply With Quote
Old 07-03-2007, 09:31 PM   #7
Please stay on topic.This is the 67-72 section.Nothing to do with a 50-66.Your post has no relevence to the problem.
Old 07-03-2007, 11:47 PM   #8
Longhorn Man
the 67 - 72 doesn't run off the horn relay. Only the horn does.
