06-03-2008, 04:28 PM | #26 |
A guy with a truck
Re: Dropmember Rear 63-72 Spy Pic
Since we have seriously thread-jacked you, Nate- getting back on track...
-What will be the advantages of this system over the KP setup? -How will it compare cost-wise? -When can we see some more pics? Quit goofing off on the internet and get back to work on this thing!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-03-2008 at 04:29 PM. |
06-03-2008, 04:44 PM | #27 |
Nate You Make Me Sick!!! That Is An Awesome Product, Now I Have To Think About Getting It!!
06-03-2008, 05:05 PM | #28 | |
06-03-2008, 06:02 PM | #29 |
One day...
Very nice!! Keep up the good work!
We all wana see it laid out |
06-03-2008, 08:47 PM | #30 | |
I do know that my kit will get less travel. I am setting mine up for right at 8" to match the front, and it will run a sleeve bag over the axle. The KP kit, I assume, would get somewhere between 10" and 12", like their square body kit. Another potential difference is that the Dropmember Rear will be 100% bolt on, while I believe the KP kit has a weld-in notch. As for pricing... mine will run $1999.00 for the complete kit. Complete Kit includes: Notch,trailing arm crossmember (without tabs for trailing arms!), four-link, bags, shocks, panhard bar, all hardware, carrier bearing support bracket (two-piece driveshaft needed on this one), instructions, and templates (for cutting the frame). More pics to come later in the week.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-03-2008, 10:49 PM | #31 | |
A guy with a truck
How tall is the notch? Set up to lay on a 30" tire like the 73-87?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-03-2008 at 10:51 PM. |
06-03-2008, 10:58 PM | #32 |
This one is set-up for a 30" tall tire as well.
06-04-2008, 12:46 AM | #33 |
3DrDwn--the 'burb not the band
Dang it now I HAVE to upgrade to 22's . I figure my 20's are barely 27" tire diameter.
Making arrangements to have body pulled off this by the end of this weekend so I should be ready slighty before you are. Then the stalking of the man in brown can begin Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
06-04-2008, 11:08 AM | #34 |
A guy with a truck
Nate- Will this ship via UPS? I think the front kits were too big to ship, correct?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-04-2008, 12:09 PM | #35 |
My DM front came ups although the box had a rough go. Also from talking to Nathan about the rear design it has been designed to ship UPS.
Josh
06-04-2008, 12:15 PM | #36 |
That skinny AZ boy thinks of almost every angle. There's always @ least one customer that keeps him on his toes though .
06-04-2008, 04:33 PM | #37 |
Looks good Nate, tell your Pop's he is doing one heck of a job My wife keeps asking if anything has been done on this yet as she wants one for her 63 GMC Just go ahead and send me one and I will have her install it to show how user friendly it is
So Nate will this work with a 4x4 frame as well as a 2x4 fra, leaf or coil? If so you need to pick up a clean AZ 4x4 Blazer and put your products were your key board is! Sure would make it easy for guys to get their "2wd Blazers". Kevin LFD Inc. Last edited by Rokcrln; 06-04-2008 at 04:45 PM. |
06-05-2008, 12:21 AM | #38 | |
Also, I have gained enough experience with UPS to understand that they do not take it easy on packages... especially the heavy ones! After dealing with torn box issues in the beginning, I have since switched to double boxing all components (two double walled boxes, with hardware and other pieces boxed inside) ... a little more spendy for me with the custom sized boxes, but I haven't had a "lost" component since.
06-05-2008, 12:27 AM | #39 | |
I don't think this particular piece will work on the 4WD chassis... but that's definitely in the future. However, on the leaf sprung chassis... the rails are the same as the coil sprung trucks with one small difference, there are ridges pressed into the framerails to cradle the leaf spring perches. This chassis is actaually a leaf sprung chassis. As soon as I finalize the four-link design, I am bustin out my 65 big-window and doing a complete front and rear install... just to "verify" things . For some reason I think that the 65 will end up with a for sale sign as soon as the rolling chassis is Dropmember Equipped.
06-05-2008, 12:28 AM | #40 |
Careful... I weighed myself on my shipping scale today, I have actually gained a few pounds!
06-05-2008, 12:50 AM | #41 |
You're so vain . . ....
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 06-05-2008 at 12:51 AM. |
06-05-2008, 12:55 AM | #42 | |
Josh
06-06-2008, 06:31 PM | #43 |
Porterbuilt- I've used the following bag for the past 2 1/2 years over axle with no problem on an 89 FSC. http://cgi.ebay.com/ebaymotors/13-li...spagenameZWDVW I really like the extra lift you get out of them without gaining all the hieght when compressed. I was wondering if these would work with the rear drop member without a lot of mods? I have a 72 I'm itching to bag now. Thanks in advanced for the info
Dale |
06-06-2008, 07:10 PM | #44 |
86 C10
Again good azz work very nice
1986 C10 2001 chevy silverado purchased 8-29-09 sold 2004 silverado purchased 8-27-10 sold |
06-07-2008, 10:15 PM | #45 | |
1990 Dodge Ram D250 Cummins |
06-12-2008, 12:05 AM | #46 |
OK guys... my OCD kicked in over the past week, and I ended up modifying the notch in order to make installation MUCH easier. The new notch design is a three piece... the main notch will slide over the rails, it will get bolted in place, the bridge then bolts in place, then the frame section gets cut-out, and finally the inner bridge cap/supports get bolted on. This thing is a beast...
06-12-2008, 12:06 AM | #47 |
more...
06-12-2008, 12:34 AM | #48 |
PorterBuilt Man Crush
Looks Great always thinking ahead
The 72 will live again |
06-12-2008, 12:37 AM | #49 |
Ya better take that puppy to the Vet cause it looks SICK!!!!!!!!
1970 2wd short/fleet 350/350 Project "iced green dream" http://67-72chevytrucks.com/vboard/s...d.php?t=272702 2006 Toyota Tacoma double cab 4x4 |
06-12-2008, 02:56 PM | #50 |
A guy with a truck
Will the inner bridge cap be one piece? Would you have a problem towing with this setup?
