Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 03-21-2023, 09:53 PM   #201
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Re: '60-'62 POwer Brake Booster Adapter Bracket With A Clutch
Originally Posted by Captainfab View Post
What options are you confused about?
Payment sent! Thanks John
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 03-26-2023, 11:05 PM   #202
Captainfab
60-66 Nut
Payment received, thank you. 😊
Old 05-11-2023, 09:45 PM   #203
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
I have received your kit. I'm in the process of installing the master to the pedal. I'm having a bit of issue. The round spacer you gave me is too long. Here are some pictures attached My truck is a 62 GMC two-wheel drive and it has the big return spring on the pedal, everything else seems to be lining up perfect booster ,master. And the clutch master The clutch master feels like a pushing great when I push it by hand Thanks!
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 05-11-2023, 09:57 PM   #204
Captainfab
60-66 Nut
That's because my booster bracket with the hydraulic clutch is designed to be used without that secondary return spring. Not all '60-'62 trucks have that extra spring. Is your truck a C1500? It almost looks like your clutch pedal is bent farther to the left than normal. If you end up needing a shorter standoff. please send me an email. That is how I do business, via email.
Old 05-11-2023, 10:26 PM   #205
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
it is a 1000 1/2 ton i can remove that secondary arm and spring, but it still looks like it at least 1/2 inch wider i gave up tonight will try again tomorrow , email is sent.
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 05-11-2023, 10:53 PM   #206
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
it only has that one big spring to keep the pedal up, looks like couple of other guys have used it with the big spring installed , it has very small one at the clutch fork this would not be enough to keep pedal up but I'll see what i can do tomorrow email was sent to john@customfab-cda.com is that correct email?, would like smaller stand off. thanks
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
Old 12-05-2023, 07:00 PM   #207
jzorn94
Junior Member
I'd like to order a bracket. No powder coat. 3/4" master cylinder. Thanks.
jzorn94 is offline   Reply With Quote
Old 12-05-2023, 07:54 PM   #208
Captainfab
60-66 Nut
All 35 of my products can be seen and purchased in the online store on our website. Here is the link.
https://customfab-cda.com
