02-26-2009, 11:19 PM | #1 |
Wide n'Low
Re: Project 50th C5 Blazer
Pictures as promised.
If you look close, you can see the rear tires are touching the wheel well. And the front it is staying up due to the front shocks being to long.. But like I said earlier It's Home!!!!!!!!!!!! now the real tear down begins.. And here is one with my son's 75 Blazer looking nose to nose..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
02-26-2009, 11:26 PM | #2 |
I have a radical idea!
I simply can't wait to see that bad boy in gold and white!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-27-2009, 10:07 AM | #3 |
Very Nice Project - great idea with the big block...one day I will have a big block 2wd Blazer [dream - dream].
I keep checking your thread for updates and pix. |
03-05-2009, 11:50 PM | #4 |
Wide n'Low
So, since I have been slammed at work for the past few days I have done nothing on the Blazer. I did however start my research on the 454.
Seems what I have at the moment is Block - 361959.....454.......73-90...2 or 4 bolt Heads - 346236.....75-87...oval...OPEN...454, 120cc chamber, 225/116cc ports Build dates Dec 78 Peanut Ports! yeah.... Ok Ok, on a happier note, I did fine a good set of 049 and some 781 heads locally, and will go look at them this weekend. So in the meantime, I am finishing up the details to get my 78 swb back to driving condition (it's only been a year and and half).. I am also configuring my shop space while making a lift setup to aid me when I pull the tub back off the chassis. I hope to make some headway over the weekend.
03-05-2009, 11:57 PM | #5 |
great job on the suspension.
MY POND TRUCK BUILD http://www.67-72chevytrucks.com/vboa...d.php?t=297393 |
03-06-2009, 12:09 AM | #6 |
Wide n'Low
Thanks,
I bounced idea's back and forth with Livrat, and by searching threads on the boards. Other members like Hotrodhomi also helped. I can't wait to get all the finish welding done and get the frame blasted, painted, and back together.. I've decided that I am going to run hard lines for my air setup, I still have to decide on air management, valves, tank, compressor etc... so I want to have those items decided before I finish the frame in case I need to fab any other mountings and what not. I look forward to seeing how it rides!
03-06-2009, 12:13 AM | #7 |
One year I am going to do similar to my burb. Right now it is acting as a rolling mini storage.
03-06-2009, 07:54 AM | #8 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 03-06-2009 at 07:55 AM. |
