09-21-2019, 11:54 AM | #1 |
How do I lower a K5 2 wd
There doesn't seem to be a kit available to lower the rear of a 1977 2 wheel drive K5 4". What problems do you encounter with a C10 shackle hanger kit? Can it be made to work? Is there another way short of a flip kit and then raising it slightly with a 4X4 hanger. Dearching and/or removing leaves? Any feedback is appreciated. Thanks
09-23-2019, 11:14 PM | #2 |
Re: How do I lower a K5 2 wd
Didn’t realize I asked such a difficult question.
09-24-2019, 07:37 AM | #3 |
67-72 parts collector,…
Pulling leaf springs will give you wheel hop.
I've done dropped leaf springs and a longer rear shackle, but that gets into re-routing the fuel filler hose. I like the flip kit and 4x4 rear hanger method. That gives the best stance, but you will need to c-notch the frame. Aftermarket 4-link is another option.
09-24-2019, 11:56 AM | #4 |
Thank you Keith
09-24-2019, 12:03 PM | #5 |
Is the c notch for blazer the same as the c10?
09-24-2019, 12:51 PM | #6 |
I believe they are different.
Crown Suspension sells a "blazer specific" notch. I'm sure there are a few other companies that do also. https://www.ebay.com/itm/Crown-Suspe...-/181848752516
09-24-2019, 12:56 PM | #7 |
I looked on lmc and there wasn’t one for blazer. Thanks for your help.
10-11-2019, 01:42 PM | #8 | |
10-11-2019, 10:16 PM | #9 |
Check out United By Trucks on YouTube , 2 wheel drive Blazer Chassis . One of our newer videos . More to come .
10-13-2019, 02:20 PM | #10 |
Here’s how I lowered mine. No notch and it’s never bottomed on the frame.
http://67-72chevytrucks.com/vboard/s...d+to+buy+%9177 |
