11-14-2018, 10:26 AM | #26 |
Re: Towing / Hauling thread.
Hauling a backhoe? you mean like this? no problem. any day of the week.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
11-14-2018, 10:30 AM | #27 |
what about a 14K crane?
11-14-2018, 10:33 AM | #28 |
no idea what all this pallet racking weighed, but it felt heavier than the pieces of equipment for some reason. there's also a 4ft high stack of 4x4 plywood in this load also.
11-14-2018, 10:53 AM | #29 |
Junior Member
Are those Dodge rims? They look good. Bolt right up? What's your center cap?
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Gold White Fleetsides/Saddle |
11-14-2018, 11:59 AM | #30 |
IIRC, mine weighed in at about 6400 lbs
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
11-14-2018, 03:32 PM | #31 |
C10 pulling a K10.
Andrew 1953 3100 292 T5 1985 K5 Blazer 350 700R4 208 |
11-15-2018, 08:06 AM | #32 |
84 K30 hauling 12,500 lbs of granite gravel....
11-15-2018, 10:25 AM | #33 |
Let's see what I can find:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-15-2018, 10:30 AM | #34 |
Few more:
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-15-2018 at 10:35 AM. |
11-15-2018, 10:32 AM | #35 |
Precious cargo:
11-15-2018, 05:46 PM | #36 |
about 4500lbs
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
11-15-2018, 11:55 PM | #37 |
mostly haul toys with mine...
all in, everything- a bit over 16 000lbs not the heaviest load, 'bout 300 clams worth of empty beer and pop cans... heaviest ever on my crew, 5 or 6 yrs ago my boss'es '79 1700 loadstar took a crap at the job with 5 tons of torpedo in it plus a 5 ton dump trailer hitched to it, also full. prob close to 30 000lbs. flat towed it 5 miles back to the shop, was no effort even when buddy dropped it into 2lo to try bump start it |
11-17-2018, 05:09 PM | #38 |
Contributing.....
This is the only pic of my current tow truck w/a load. Unfortunately, only the patient on the trailer was photo'd LoL.
11-17-2018, 05:12 PM | #39 |
My old 74 however did better when it came to photo op's....
11-19-2018, 11:28 AM | #40 |
The only thing I haul with my '84 is my lunch..
11-19-2018, 05:58 PM | #41 |
they are dodge rims, with 2" spacers, 95-ish chevy threaded lugnuts and centercaps.
08-29-2019, 03:26 PM | #42 |
Junior Member
Picked this up for $100.
Do squares not haul as often as 67-72's. Thay have way more posts in their thread.
08-29-2019, 05:06 PM | #43 |
k30 doin k30 things .
free mulch grindings from local county compost lot . they even load them for you . the only problem is you have to level them out were you dump them . few more loads to go for the finish product to be done .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-29-2019, 05:12 PM | #44 |
Junior Member
Damn that K30 barey squats with mulch cab high! I gotta get mine back on the road.
08-29-2019, 05:32 PM | #45 |
A little late night rescue a month or so ago. Timing gear went out/sheared the teeth on this regularly driven Model-A. It's owner is a 24yr old young man who knows them front to back & isn't scared to modify them so they can be driven.
But, in the end, it was maneuvering this load & the dually in the shop parking lot that killed my 7k mile rag-joint. Thankfully we were already 'home' so we were able to just band-aid it to get it parked so I could repair it later.
08-29-2019, 05:41 PM | #46 | |
timbren bump stops on 3/4 ton springs so it rides better than a k30 but has more weight hauling capacity over just the std k30 springs . if i wanted i have a set of 4,400 lb HD springs i could install but then my ride would go to crap .
09-09-2020, 09:55 AM | #47 |
Junior Member
Estimated 4500 lbs. Old pump house foundation. Squat the K30 pretty good.
