05-26-2020, 10:59 AM | #1 |
Cab Floor seam sealer
Recently I purchased the full replacement floor for my 68 from AMD through Nsane Parts. I am 95% certain I am going to sandblast the ecoat off and epoxy prime. The ecoat does not transfer when I rub it aggressively with Lacquer Thinner, however the ecoat blasts off rather easily. My main question is once I epoxy prime it, I am going to put raptor liner on the underdside. Will the raptor liner be enough or should I use a seam sealer where all the panels meet?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
05-26-2020, 12:30 PM | #2 |
Re: Cab Floor seam sealer
The raptor would probably seal it , but if mine I would blast, epoxy,seamseal,epoxy over that,then raptor
05-26-2020, 01:04 PM | #3 |
That was roughly my plan, but putting a coat of epoxy over the seam sealer is probably a good idea to seal it all, then put the raptor on. Do you have a suggestion for seam sealer? Thanks.
05-26-2020, 01:23 PM | #4 |
I used 3m brand that fits a standard caulking gun on mine
05-26-2020, 03:06 PM | #5 |
Clean up the panels. Put 2 coats of Rusbullet and as soon as a 2nd coat dries put a tack coat of the raptor and follow it up with a full coat of raptor. That creates an airtight seal that will last for many years Be sure to use the silver formula and not the black
05-26-2020, 03:54 PM | #6 |
Thanks Lupo, I have already purchased my epoxy and will use it as I have sprayed it several times and really like the finished product. I purchased the gallon epoxy and the gallon of activator, so two sprayable gallons means I can put on several coats.
05-26-2020, 04:03 PM | #7 |
Okay that should do the job. I have a tendency for overkill
05-26-2020, 09:40 PM | #8 |
Epoxy primer is only effective if applied to bare metal, so put your Raptor right over the seam sealer.
Just a thought... why not just paint it instead of urethane bed liner? It's cheaper (single stage vs Raptor), it's far easier to apply, far less mess and can be removed on purpose a whole lot easier than bed liner. Bedliner is not good for sound deadening if that's what you're after. No harm in putting bedliner under your truck but I don't see the benefit. Your truck, you do what you want.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
05-26-2020, 10:14 PM | #9 |
Raptor liner specifies in the instructions (do not apply over exposed or uncoated seam sealer)
05-26-2020, 11:07 PM | #10 | |
06-29-2020, 01:27 PM | #11 |
I have finished blasting/epoxy priming my cab floor. Looking for some insight on where to apply the seam sealer. In the below picture I will seam seal where the red lines are. I do have a question about the red arrows. There is a bit of a gap there, and am unsure how easy it would be to fill, or if i need to fill it at all?
Floor pics: Gap at rear of floor, note the fuel line pass through hole. Should I attempt to seam seal this gap?
06-29-2020, 02:19 PM | #12 |
Probably wont hurt anything..that crossmember has drain holes in the bottom of it..so your really not sealing anything
You may want to shoot cavity wax in that crossmember ..
06-29-2020, 02:36 PM | #13 |
Thanks Greg. I will look into putting cavity wax in there as well as the other supports that may need it. Hoping to get another 50 years out of this floor.
07-09-2020, 08:00 PM | #14 |
After epoxy, I caulked seams with polyurethane caulk. ( Sika Flex 1A) Tried to leave drain holes open, then sprayed Raptor liner over top.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 07-09-2020 at 08:02 PM. Reason: add pic |
07-09-2020, 09:08 PM | #15 |
Nicely done. Mine looks similar on the seam sealer. I put epoxy over the seam sealer once it cured for 24 hours, but am waiting to put my raptor on until I have my floor in. Did you have to do any lower A or B pillar work?
07-10-2020, 01:40 PM | #16 |
No, cab was surprisingly solid....someone undercoated it. Old undercoating was flaking, removed it, down to original primer. Then recoat........Same here trying to make it last another 50 yrs.
