Old 02-16-2019, 10:09 PM   #1
mygmctruck1
Test dash cluster
How can I test dash cluster lights out side of dash.
mygmctruck1 is offline   Reply With Quote
Old 02-17-2019, 01:11 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Test dash cluster
You could build one of these.
http://67-72chevytrucks.com/vboard/s...d.php?t=732873
Any small 12 volt DC adapter will work.
LockDoc
Leon
Old 02-17-2019, 04:01 PM   #3
mygmctruck1
LockDoc
Actualy I want to be sure the printed circuit board works
Old 02-18-2019, 08:45 AM   #4
Mike C
Mike C's Avatar
Just check continuity from one end of a circuit to the other with an Ohm meter if all you are doing is verifying the printed circuit is good.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-18-2019, 09:16 PM   #5
bill3rail
bill3rail's Avatar
Get a dash plug and plug it in to the back, feed +12Vdc to the proper wires and it should light up.
You can feed the power directly into the circuit board, but having the plug with stripped wires is easier.
P.S. there are wiring diagrams all around here to see where power goes in.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 02-18-2019, 10:29 PM   #6
Sparky dave
You can find out which wire is positive and negative by just looking on these. Look for the dash light bulbs on the circuit board and you can follow the tracks on the circuit board all the bulb positives join together and go to a wire and all the negatives go together and become a black wire. I'm pretty sure the dash positive wire is pink but check first. Then touch the wires to your car battery or another 12 v battery
Sparky dave is offline   Reply With Quote
