Old 10-27-2010, 06:24 PM   #1
DG Racing
DG Racing's Avatar
Serial Number
Where is the serials numbers on a 1957
DG Racing is offline   Reply With Quote
Old 10-27-2010, 06:36 PM   #2
Tommy454
Tommy454's Avatar
Cool Re: Serial Number
Your truck should have the vehicle identification number stamped on a stainless steel plate that is attached on the left front door hinge post.
Also check the driver side frame directely across from the generator, area. The number is be stamped in, Wire brush this area and it should appear.
Tommy454 is offline   Reply With Quote
Old 10-27-2010, 11:36 PM   #3
Kim57
Kim57's Avatar
Re: Serial Number
The frame number can also be under the cab on the drivers sid. That's where it is on mine.
Kim
Kim57 is offline   Reply With Quote
Old 10-27-2010, 11:56 PM   #4
DG Racing
DG Racing's Avatar
Re: Serial Number
ok yes its on the driver side frame directely across from the generator, area.
but on the stanless blue plate attached on the left front door hinge post its only gvw rating and color paint no.
no plate with serial number on it ??
Old 10-28-2010, 12:23 AM   #5
bobinbc
bobinbc's Avatar
Re: Serial Number
Higher up, in the door jamb area of the windshield frame, driver's side
1962 Chevy blue SBFS
1957 Chevy yellow SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 10-28-2010, 01:55 AM   #6
kalirodding
CLASSIX Truck Club
kalirodding's Avatar
Re: Serial Number
My 55 was right on the upper part of the cab door jam, and my 59 had it on the cab inside the door jam between the 2 door hinges.
kalirodding is offline   Reply With Quote
Old 11-16-2010, 06:24 PM   #7
DG Racing
DG Racing's Avatar
Re: Serial Number
Can someone post a picture of what the vin plate in the drivers door frame looks like in a 1957 Chevy
Want to see exactly what one looks like.
thanks
Old 11-16-2010, 07:40 PM   #8
sgtusmc
sgtusmc's Avatar
Re: Serial Number
Here's what's on my 1959. My apologies if the 59 is not the same as the 57.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 11-17-2010, 01:21 AM   #9
Kim57
Kim57's Avatar
Re: Serial Number
Here's the one on my cab. I believe it's a 55 but the one on my original 57 cab was identical.
Kim
Old 11-20-2010, 01:00 AM   #10
DG Racing
DG Racing's Avatar
Re: Serial Number
ok thanks for the pictures
