Old 07-15-2018, 09:46 PM   #1
davecarney2
davecarney2's Avatar
Trying to identify front suspension
Father in law just bought a 51 Chevy 5 window. Thinking this is a mustang ii front in but I'm guessing. Truck has some body roll. Trying to figure out what to do to minimize it and make it handle a little better.
Sorry the images are upside down
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
http://67-72chevytrucks.com/vboard/s...d.php?t=592878
davecarney2 is offline   Reply With Quote
Old 07-15-2018, 11:05 PM   #2
oldman3
oldman3's Avatar
Re: Trying to identify front suspension
Yes, that is the orginal style MII with the rear brace. You don't have a front sway bar, that will make the front end tilt side to side. Install a sway bar and it will be better. Also the bottom control arm should be paralle to the crossmemer. Someone may have cut the spring, or it isn't heavy enough. You have very little travel with the shock...Jim
oldman3 is offline   Reply With Quote
Old 07-17-2018, 05:56 PM   #3
davecarney2
I'll pass this along to him. Are they pretty much all the same for certain years making finding on to fit fairly universal.
Bagged 1959 GMC
1969 C-30 dump
My 59 build.
Old 07-17-2018, 11:26 PM   #4
oldman3
oldman3's Avatar
I think the MII and Pinto front end was from 1974 to 1978 and were all the same. You can buy parts from many venders. Speedway has lots of different stuff for them...Jim
Old 07-18-2018, 12:55 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Agree, MII setup.
To get those to handle and not have bump steer issues, the lower arms need to be parallel to the ground at ride height. If they are stock height spindles, I would replace with dropped spindles and get springs to get the arms back to level.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-19-2018, 06:51 AM   #6
PGSigns
PGSigns's Avatar
That one is going to have some bump steer issues. I would take a measurement on the toe as it sits now and then jack it up three inches and recheck the toe. I think it will pick up 1/4 to 3/8 of an inch. It needs a sway bar and the shocks replaced.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
