03-08-2019, 12:13 AM | #1 |
Tail light wiring
So the 70 c10 I have, has a 3 wire tail light, the oem connector I ordered from lmc truck has 2 wires. On the truck 1 wire runs to 1 connector and the other 2 wires run to the other connector. So I'm wondering why the oem connector from lmc truck only has 2 wires when the one that came with the truck has 3?
03-08-2019, 10:58 AM | #2 |
Re: Tail light wiring
Tail should have 4 wires. Start at the plug by rear driver tire. Google c10 tail light wiring
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
03-08-2019, 04:04 PM | #3 |
I'm focused on the brake light not the reverse light. So on the brake light connector it has 3 wires, 1 goes to a plug and 2 go to the other plug on the connector and the oem plug I got off lmc truck only has 2 and doesn't have the other wire. So I might have to modify it to accommodate the 3rd wire it has on the truck. Just seems weird that an oem plug just came with 2 wires.
03-08-2019, 11:48 PM | #4 |
Msgt USAF Ret
Here's the wiring diagram for the tail lights.
The left light has three wires, one for the brake/turn and one for the tail light plus one for the license plate light. The right light has two wires, the dark green for the brake/turn and the brown one for the tail light. Both lights ground through the sockets to the frame as does the license plate light.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-08-2019, 11:55 PM | #5 |
Thanks for the diagram, I went to the junk yard and looked at some 70 c10s and they had the 3 wire brake light as well but on all the ones I looked at the wire was not connected like they had been cut and only had 2 of the 3 wires connected. Kinda weird. But I appreciate the diagram. It helps
03-21-2019, 12:04 PM | #6 |
Gm just used that spot to run the licence plate light.
2 wires is what you need, you can run the license plate wire from anywhere on that brown circut
