Old 03-20-2019, 07:25 PM   #1
ccautoupholstery
Brake upgrade question
I have a 67 c10 that I'm in the process of converting to power steering and power disc brakes up front. I ordered the booster/master/prop valve from brothers and just got it yesterday. The old lines for the front arent the correct size or in the right spot, also not same size for caliper hose connection. I'm hoping someone can help me with info on parts needed...size of brake line used and fittings needed..thanks in advance
ccautoupholstery is offline   Reply With Quote
Old 03-20-2019, 10:57 PM   #2
ccautoupholstery
Re: Brake upgrade question
I think I managed to find everything I needed after driving to every part store in town. Does anyone know what I should use on the threads when installing everything? PTFE? threadlock?
Old 03-20-2019, 11:20 PM   #3
cornerstone
cornerstone's Avatar
I may be wrong but for brake lines don't use anything! The flare is what does the sealing and anything else may cause a problem. I'd wait for smarter folks than me to verify that first....
Brian
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 03-21-2019, 12:41 AM   #4
Russ.W.
Russ.W.'s Avatar
Brian
Correct. No need do add anything to assist in sealing threads on brake lines.
Old 03-21-2019, 05:24 PM   #5
ccautoupholstery
Next question, where do I run my vacuum for my brake booster?
Old 03-21-2019, 05:27 PM   #6
HO455
Post Whore
HO455's Avatar
What engine do you have?
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 03-21-2019, 06:00 PM   #7
ccautoupholstery
350 out of a 78 camaro
Old 03-21-2019, 06:15 PM   #8
kev2809
low n' slo
kev2809's Avatar
does your carb have a port for it? thats where i ran mine...
if not, your intake should have 3/8" port behind the carb. mine had a tee fitting there for the trans modulator line and the booster line.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-21-2019, 06:40 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
However, I wouldn't run a brake booster and a vacuum modulator for the transmission off of the same line. The factory had them come from dedicated sources. The booster came from the rear of the carb and the modulator came from the fitting on the intake manifold.
You don't want the vacuum source for either one of those interupted by another source sharing the same line.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-21-2019, 07:05 PM   #10
ccautoupholstery
Gary
Thanks for the info! I happened to find some old pics from when I pulled it from the camaro and found the line off the carb that I had plugged..I think the last thing I need to figure out,is how to set the rod length from booster to pedal, do I just set it to where there is no slack before depressing the pedal?
Old 03-21-2019, 10:25 PM   #11
jradford
Just make sure to run vacuum from below the throttle plate. That way you will have good vacuum at low throttle and idle for the brakes.
jradford is offline   Reply With Quote
Old 03-21-2019, 10:35 PM   #12
kev2809
low n' slo
kev2809's Avatar
Gary
yup. with my new carb i ran the booster straight to carb, modulator line to the tee fitting and capped off the original booster fitting on the tee.
wasnt sure if the OP had a port on the carb for the booster
-_--_--_ _________
Old 03-21-2019, 10:41 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
You should have 1/8" of free pedal so that you don't end up causing a bind. Do you have a manual for your truck? I used to have a link to post for people. One of our members was gracious enough to upload a lot of the manuals. You can search for it, and get the correct free pedal adjustment for the brakes. For 1970, it's on page 5-10.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
