03-25-2020, 10:19 AM | #51 |
SWB 4x4 Collector
Re: 1972 Chevy K20 Extended Cab Cummins Build
Getting it figured out.... that's half the fun!
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
03-28-2020, 09:40 PM | #52 |
today we got the door latch pocket tack welded on in the correct position and the weather stripping lip from the rear of the passenger side cut and re shaped to fit the front of the drivers side.
03-29-2020, 06:31 PM | #53 |
got the upper door jamb spot welded in and working on the lower pillar, almost done.
03-30-2020, 10:32 PM | #54 |
today I worked on the various puzzle pieces that will be welded to the 4th door pillar to match the passenger side, I hope to be tacking them in tomorrow
04-01-2020, 08:27 AM | #55 |
Your making super fast progress on your post. Looking factory to me. I love seeing how different peoples approach to making this pillar are. Keep up the good work. Took me about two weeks to make my post... hours of welding ahead of ya..
Posted via Mobile Device |
04-01-2020, 11:09 AM | #56 | |
04-02-2020, 10:33 PM | #57 |
Got the rear of the pillar tacked in place and the latch pocket moved back where it needs to be.
04-03-2020, 09:50 PM | #58 |
Got the bump out on the pillar tacked on today, feels good when stuff fits like its supposed too.
04-04-2020, 10:12 PM | #59 |
today we got the pillar welded in and the temporary latch for the drivers door made and installed so it all works, tomorrow the plan is to get the suburban cut off and the back of the truck cab put on
04-06-2020, 10:52 PM | #60 |
Sunday we got the suburban back off and the truck back sat on, the nest step is to mount the rear to the cab
04-07-2020, 09:39 PM | #61 |
got the cab sitting in a more correct position, had to cut out the window track as expected and lined the drip rails up with clamps
04-09-2020, 04:10 PM | #62 |
Amazing work.
Jack |
04-19-2020, 10:06 PM | #63 |
got the rear cab tacked to the suburban, we made an 8 inch long inner support manel to tie the two together and even with a few welds seems very strong, the mock window pillar is also welded in until we use a full other pillar to weld into the door like the original, the two line up real well. mucking up the cab corner to make sure everything fits an then lock down the drivers side so we can make that door. also I buffed out the original Ochre door that will contribute to the fourth door to look at it in person. I was set on blue but I have always liked the yellow and I think that is the direction I will go, with the white top and no trim.
04-19-2020, 11:20 PM | #64 |
Looking good.
Great progress. I like that Ochre color also. .
04-20-2020, 06:52 AM | #65 |
That color will look good. Nice progress! What’s the white stuff on the green grass?
71 C10 72 K20 72 K10 Super Kirk |
04-20-2020, 06:16 PM | #66 |
04-21-2020, 10:49 AM | #67 |
SWB 4x4 Collector
Looking good!
04-21-2020, 11:02 PM | #68 |
got the drivers side cab corner on and looking good, the rocker is just screwed in place. the passengers side cab corner was welded on but the corner didn't fit right and tapered in on the bottom, after checking the contours of another cab we realized they both should be the same and the passenger side is not, most likely it was twisted while doing the drip rails. we just need to cut and form a bit until its close. also the drip rails line up perfectly on both sides.
04-21-2020, 11:03 PM | #69 |
The contour as compared to the drivers "correct" side.
10-13-2020, 12:24 PM | #70 |
work on the project is on hold right now as we bought a theft recovery 2019 Duramax and had to put it back together. I was looking through the "Trucks in the Wild" Thread and came across a picture of the White C20 I bought from 2018, sitting in the same exact spot as when I picked it up, thought it was interesting
10-20-2021, 08:02 PM | #71 |
I am hoping to start back up on this build here soon, the plan has changed, I put the 12 valve 5 speed into a ext cab short bed dodge, I sold that truck and made some money, I have now switched to a duramax chassis for my swap. I got a donor truck a month back, 2005 lly crew cab long bed.
10-26-2021, 12:39 AM | #72 |
Too bad you're in Indiana, I need that 06 HD hood! Great progress on the truck.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Tags |
1972, chevrolet, cummins, k20 |
