08-16-2019, 09:00 PM | #1 |
Edelbrock 600cfm carb idle will not stay steady
I have a edelbrock 600cfm carb on a stock 350 chevy except for the usual edelbrock intake manifold. The idle goes up and down and will not stay steady. Also if I shut the engine off and try to restart it then it is very difficult to get started again...I try pumping the gas peddle once or twice but it will not start .....but if I prime the carb by putting gas into the carb from a container it will fire right up but when I get it started the idle will not stay steady. I wanted to be able to drive the truck around while I rebuild the original big block 396 for the truck.
This is a old carb that was on the truck when I purchased it from the last owner that I am just trying to troubleshoot what is wrong with it. Could it possibly be the timing chain and not the carburetor at all? Last edited by HeavyHauler; 08-16-2019 at 09:36 PM. |
08-16-2019, 09:42 PM | #2 |
Re: Edelbrock 600cfm carb idle will not stay steady
Spray some carb cleaner down the bowl vent while it’s running. Sound like your idle circuits are gummed up.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust) |
08-16-2019, 10:30 PM | #3 |
Check for manifold leaks.
Do you have power brakes?
08-17-2019, 12:29 AM | #4 |
08-17-2019, 12:30 AM | #5 |
08-17-2019, 12:38 AM | #6 | |
The Edelbrock 1405, 1406 are pretty simple carbs. Easy to fix with the available EDL-1477 kit.
08-17-2019, 09:47 AM | #7 |
Who Changed This?
If the carb has any kind of age I'd check the primary throttle shaft for a leak. It's quite common,and will give the idle characteristics you are seeing. Other things may be wrong with it, too. You can have it or get it rebuilt, and put in new bushings. It's cheaper to have them put in since the tools cost money and you may only do it once. I usually rebuild my own and have a carb shop do the bushings. Last time the guy squawked about not having the whole job. YMMV
08-17-2019, 01:05 PM | #8 |
Check your centrifugal advance weight bushings and weak springs in distributor. Replace if worn, make sure they are greased. You may be getting unwanted distributor advance creeping in at idle. You can check this with a timing gun. Make sure your centrifugal advance is starting above 1,000 rpms.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
08-18-2019, 03:05 PM | #9 |
I took the carb off the engine and I am going to take it apart and fully clean it. I have found that it is a 1405 600cfm carb.
08-18-2019, 03:07 PM | #10 | |
08-18-2019, 05:05 PM | #11 |
Sounds like you have a couple potential issues. First things first, timing. If your timing isn't correct, everything else will be off as well. GM engineers found Chevy engines run best at 36 degrees total timing, 38 at higher elevations. Set your total timing accordingly and then move on to your carb. If you plan on sticking with that carb, your best bet is to clean it out real well and throw a rebuild kit at it. Then set the float levels to specs and regulate the fuel pressure to 5.5 psi to prevent flooding. Next, put a heat insulating gasket under it, to prevent fuel percolation, which causes the hard starting after warm up you're reporting. You also have to set the transition slots in the throttle bores to be a square to ensure it's only idling on the idle circuit. What is your idle rpm set at, or the range its bouncing around at? I'm wondering if it's set too high and allowing the mechanical advance to dip in n out? Idle should be 750 rpm for auto and 600 (I believe) for manual. Which distributor are you running, original points or HEI? I agree with Caddylackn, make sure the distributor advance weights are well lubed. After messing with the carb, hook the vac advance up to manifold vacuum. Then after you get it running well, use a vacuum gauge connected to manifold vac to set the idle mixture screws for highest vacuum. Hopefully this fixes your issue and the throttle shafts are fine. If you don't already have it, download a copy of the Edelbrock instructions. All you need to know is in there as well.
72 C10 lwb fleetside -stock 350/350 combo |
08-18-2019, 05:13 PM | #12 |
Who Changed This?
It would have been easier if it was still installed and you could spray carb cleaner or something onto the shaft. But since it is off, open and close the primary butterflies while pulling the throttle linkage forward and backward at the linkage. It it moves from front to back while you rotate the butterflies you will see that they don't close all the way. Maybe even try just back and forth at the shaft without opening or closing the butterflies. It probably has detectable movement if the body of the casting is worn.
08-18-2019, 05:23 PM | #13 |
Throttle shaft bushings wear in a front to back direction on the drivers side of the carburetor. This wear is accelerated by having improperly installed springs or too heavy of return spring. (Most aftermarket springs fall into this category).
You can feel the shaft wear if you try to move the throttle shaft forward and aft. Anything more than 1/16" of play could be problematic.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-19-2019, 02:21 PM | #14 | |
08-19-2019, 02:24 PM | #15 |
I totally disassembled the carb,cleaned cleaned everything,set the floats because they were waaaaay off,put it back together and set the idle mixture screws and idle. It runs really well now. Took it for a drive and it ran the best it ever has since I purchased it couple months ago. Now I just need to fix the brakes and make them stop better.
08-19-2019, 02:31 PM | #16 | |
08-19-2019, 02:32 PM | #17 | |
08-19-2019, 02:34 PM | #18 |
Thanks to everyone who took the time to add their knowledge. My truck is now running really well. This is a great forum!!!
08-20-2019, 10:40 AM | #19 |
Glad you got it running well and glad we could help. Congrats! So did the tuning make the fluctuating idle disappear?
