Old 01-27-2020, 10:22 PM   #1
HotRodScottsdale
HotRodScottsdale's Avatar
Hard steering at idle
The truck is a 84 Silverado with the 350. Just recently I find I cant turn or have to REALLY fight to turn the wheel when stopped. I figure the power steering pump is on it's way out because the fluid looks fine. What else should I replace when I'm doing the pump? Is it worth it to replace the hoses too? Any tricks or tips?
On a quite night you can hear a ford rust
HotRodScottsdale is offline   Reply With Quote
Old 01-27-2020, 11:28 PM   #2
Bandit130
Bandit130's Avatar
Re: Hard steering at idle
If replacing pump, I would replace hoses especially if they may be original. Just a little added insurance to not worry about.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 01-28-2020, 06:25 AM   #3
Wgesnerjr
Wgesnerjr's Avatar
Make sure the belt is tight. They can slip and not squeal or make noise.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 01-28-2020, 07:44 AM   #4
Dead Parrot
2nd the thought to check the belt. They can also slip easier when wet.
Dead Parrot is offline   Reply With Quote
Old 01-29-2020, 02:25 AM   #5
HotRodScottsdale
I'll check the belt tomorrow, I did notice this after I washed the truck to park it. Thanks for the tip!
Old 01-30-2020, 01:34 AM   #6
HotRodScottsdale
So I haven't had time to look in the daylight but I did a quick check after work today and yes the belt is loose but I couldn't see how to tighten it. Anyone got any tips?
Old 01-30-2020, 02:41 PM   #7
truckin 79
most power steering pump brackets will have a place for a 1/2 socket to fit into and help you tighten belt. Usually have to loosen two bolts to get pump to loosen up for adjustment. If you are doing by yourself just hold tension and tighten down on one bolt. Once belt is tight enough just tighten down other bolt.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
