04-10-2017, 12:05 PM | #1 |
Questions about an inherited '72 project
HI, I am new to the forum. I joined primarily because a friend inherited what they thought was a '69 Chevy 4X4 "project". The previous owner passed away and so is not available to answer questions about exactly what he has done.
The current state is what I would call disorganized to be polite. For example: The frame is in the driveway with 4X4 transmission, drive shaft, rear end and wheels. It has been painted but I can see some rust peaking through. The bed is off and next to it. It is not painted, has rust and needs metal work. The cab is in the garage and has been painted. Fenders are there but not painted. Motor is also there. I wanted to help them out so I began examining and started with the VIN. It is located on the door panel but it is not a '69. It shows as a '72 3/4 ton 4X2. Which raised more questions because that frame in the yard is definitely a 4X4 with a T221 transfer case. I checked the frame for a partial VIN to see if at least the year matched, but can't find it. Supposed to be on right side top near steering gear box or right side mid frame. I am guessing is has been painted over. I would hate to be the person to tell them to haul it to the scrap yard as there is still some emotional attachment to "dads truck" (and we all love old trucks) however, no one in the family seems to have a passion for the kind of work necessary to restore it. So i am trying to determine the best resolution. I have many questions - is there glass, seats, instruments, chrome - but the one that seems important at the moment is: It seems to me that having a mismatched cab and frame is significant. How big a deal is it that the VIN says 4X2 and the frame is obviously 4X4? What if the frame turns out to be from a different year? Does the '72 cab require a '72 frame? After reading this, you will probably be thinking something along the lines of "Son, you are well over your head here. Your best option is to run." Yep, that is true. But I have to take a shot at it anyway. And you will be thinking "Yep. I knew you would say that" Thanks in advance |
04-10-2017, 12:37 PM | #2 |
Go Pack Go!
Re: Questions about an inherited '72 project
First off, WELCOME!!!
Post a picture of the frame. There are experts here that will be able to tell what year range it is. That will give you a place to start. A 72 cab doesn't need a 72 frame. |
04-10-2017, 12:55 PM | #3 | |
I am very relieved that the year does not need a specific match up - I will have to ask for pictures. Are there specific areas of the frame I should focus on? Front/ Rear/ Mid/ Left side or Right? |
04-10-2017, 01:17 PM | #4 |
I would think the first thing you need to find out is if you have a clean title for the truck. I think you would need the title to match the vin on the cab door post.
04-10-2017, 01:27 PM | #5 |
The frame partial VINs are on the left (drivers side) frame rail. Top of frame rail by the steering box and middle of the frame under the cab floor.
Welcome and it sounds like an interesting truck.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
04-10-2017, 01:49 PM | #6 |
If you suspect this is a later frame (73-87 or so) look on the passenger side frame rail below the door. Everything depends on what the family wants. Purists will say never mix frames and anything after that is just a hodge podge of parts. But it really depends on what the owner wants. If in the end you still have a cool truck and that's all you want then I say finish it. If having a truck that is not as it rolled from the factory is not what you want then put it on C-list. You can find "projects" on there all day long with similar stories just like this one. Good luck and definitely post some pics. It will be easy to tell from that if the frame is at least the correct year range.
1969 Chevy K20 Longbed |
04-10-2017, 02:04 PM | #7 | |
Yes, this is also a concern because the title they thought went to that truck was for an '84 (alarm bells going off). Apparently it was taken in barter for some farm work. So, I've asked to contact the other party to see if they have the title. If that does not work out, then I guess a trip to DMV (apply money) is next to see who title is with and whether it is a salvage title or something else. And then (apply more money) to get the title clear. I would bet that I would have to apply money to clear the title to even take it to a salvage yard. I am sure it varies from state to state but if you have any suggestions, pile on. If nothing else, it is an interesting project for retirement Update: I am assured by the owner that they had the title last summer - so it is a matter of finding it and checking the vin, Last edited by Steve1954; 04-10-2017 at 02:47 PM. |
04-10-2017, 02:36 PM | #8 | |
Examole: Last fall, the '94 GMC 3/4 ton 4X4 wasn't working. They said it needed a new alternator. So, I scratched my head, got my multimeter, and looked at it and no battery. Looked in the garage and there was a battery on the floor and saw a really nice battery charger in the garage. Went to hook up the charger and was told it did not work. So, I hooked it up anyway and it worked fine. Half hour later, put the battery in the truck and hooked up the side mounted screw terminals and that positive one just would not tighten. Looked at it - threads stripped. Bought a $5 terminal at Auto Zone and miracles of miracles, I fixed an alternator, battery, and a battery charger for $5. Never even got to use the multimeter. There is a '76 Sierra back in there but I am still evaluating it and it is another story for another day. I probably should keep a journal and write a book Last edited by Steve1954; 04-10-2017 at 02:49 PM. |
04-10-2017, 02:56 PM | #9 | |
I actually knew that - what I forgot was my left from my right - LOL. I have been researching and have a pretty good idea of where it should be, just hesitant to start sanding off paint I guess. |
04-10-2017, 03:37 PM | #10 |
A few posters above said someone might be able to determine if this is a '72 chevy pickup frame, or maybe the approximate year.
Photos of frame are attached (please don't be from a 1964 Massey Ferguson MF 185) Did I mention that it was yellow? Last edited by Steve1954; 04-10-2017 at 07:36 PM. |
04-11-2017, 01:45 AM | #11 |
Hi Steve, and welcome..that frame is a 69 or 70 frame,since it looks like it has front drum brakes, it would be a 71 or 72 if it had front disc brakes, it is a dana 44 front end with an eaton rearend, it isnt a np 205 trans case either...looks like a dana 20...correct for 69-70...if it has a current title who cares if the cab says 4x2...build it and have a nice truck, nice that it is a 3/4 ton frame and axles, and dont haul it to a scrapyard, there are plenty of guys on this forum that would buy the rolling chassis right now,alot of guys want to convert their trucks to 4x4, and all the rest of the parts are in demand too, you just have to pay the $25.00 fee to be a paid member to sell things on the forum
04-11-2017, 09:51 AM | #12 |
Looks like a good start to a nice 3/4 ton project....but yellow?
For the most part 67-72 parts all work together as far as cabs and beds. Fenders,grills and core supports are important to get the correct peices so everything matches. Be sure the cab has a high hump to fit over the trans. A set of 3/4 ton cab mounts and four guys and set the cab back on. Peice it together then pull it all apart for refinishing.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-11-2017, 12:53 PM | #13 | |
That bit of information actually brightened my day a bunch. The transfer case has a metal tag - Rockwell T221 N 7, Serial Number 02690216. Transmission has "GM1" "C249" "3901131". I've googled Rockwell T221 N 7 and found the T221 was used up to '69. No specific reference for "N 7". The best I have come up with on the trans is possibly a Muncie SM465 which stated in light trucks in 1968 and went to 1991. I read the forum rules about selling and understand the $25 fee - which is very reasonable. |
04-11-2017, 01:02 PM | #14 | |
I am going to get a clip board and start cleaning out that area and make an inventory next week. They say the cab mounts are in there but I will feel better when i have actually put my hands on what is there and get it organized. |
04-11-2017, 01:27 PM | #15 |
I'm leaning towards the frame being a 68 maayybee a 69. No later than that
04-11-2017, 01:48 PM | #16 |
Go Pack Go!
Looks to be a keeper for sure. Paint that sucker black and start assembly.
04-11-2017, 04:45 PM | #17 | |
04-11-2017, 05:38 PM | #18 |
That tranny/t-case combination is what my truck has. The set-up is pretty much bullet-proof.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
04-11-2017, 09:17 PM | #19 |
and there are two engines back there that I have to suss out
04-12-2017, 08:23 AM | #20 |
Welcome, you are off to a great start.
70 c 10 daily Rider |
04-12-2017, 06:52 PM | #21 |
My original questions seem to have been answered.
Summary: How big a deal is it that the VIN says 4X2 and the frame is obviously 4X4? What if the frame turns out to be from a different year? Does the '72 cab require a '72 frame? I think the answer is: a) if I am a purist, it would be important. I am not. b) if the frame is a '67 to '72 frame, it will mechanically fit. Consensus is that the frame is '68 or '69 (based on front drum brakes). although the cab "hump" needs to fit over the transmissiona and transfer case and there needs to be an opening in the floor board for the stick. c) title needs to be resolved d) the frame really needs to be painted something other than yellow however, since someone painted it yellow, it is probably important to be definitive so as not to end up with a pink frame. Paint it black. |
04-12-2017, 08:23 PM | #22 |
another thing, if that frame has been sitting in the weather uncovered, the transmission is probably full of water and is junk...
04-12-2017, 08:24 PM | #23 | |
04-12-2017, 09:30 PM | #24 | |
I could not figure out why the gentleman did not pull the trans - he has engine stands and a hoist. Just have to work with what is there and check them out as I go. I appreciate your concerns - keep piling them on. LOL |
04-12-2017, 09:34 PM | #25 | |
