Old 01-08-2011, 12:27 AM   #1
turbotravis
brake booster relocate
Do any of you guys know how i can either mount a later modle booster or somehow make the power brake system smaller or closer to the fire wall. I am building my twin turbo deal and the factory brake system is in the way. on the last truck i made it manual brakes and for racing it was ok but on the street i need to be able to stop fast.
turbotravis is offline   Reply With Quote
Old 01-08-2011, 12:37 AM   #2
dixietruck71
dixietruck71's Avatar
Re: brake booster relocate
I would also like to know the same thing im sick of looking at the huge booster/master. It just looks like an after thought.
dixietruck71 is offline   Reply With Quote
Old 01-08-2011, 01:05 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
I bought a stainless dual diaphram 7" booster and it bolted in place... looked great and would never rust... they are available from most vendors or hot rod shops... or you can get the gold cadmium plated ones for a fe bucks less...
Rich
1972 K5 Blazer CST Click HERE
Old 01-08-2011, 01:28 AM   #4
treveiger
treveiger's Avatar
Can i ask how much they run? How does it work? It just bolts right in place without any mods?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-08-2011, 02:11 AM   #5
mcmlxix
mcmlxix's Avatar
You can google it to find multiple source... and there is always eBay.... anywhere from $85 for zinc coated to $200 for a nice stainless one... there is chrome too but rust may creep in after a while depending on quality or the chrome...
Amazon.com: 7" Universal Dual Diaphragm... Amazon.com: 7" Universal Dual Diaphragm...
They should just bolt in place... there are 4 studs that should line up with factory ones...
Rich
Old 01-08-2011, 03:21 AM   #6
turbotravis
is there anyone who has put a late modle booster right on the fire wall? if so how
Old 01-08-2011, 10:23 AM   #7
Boog
laying low
Boog's Avatar
TTT for ya as I am also thinking about using one from a 97 I have.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 01-08-2011, 11:07 PM   #8
Fitz
Bolts right up to the mount and pedal linkage for the one you have and uses the same master cyl.
The 7 inch Dia booster is available from Carolina Custom trucks, 179.00 in stainless, 169.00 in chrome. http://www.carolinaclassictrucks.com..._boosters.html
Fitz is offline   Reply With Quote
Old 01-09-2011, 12:26 AM   #9
tonypaul
tonypaul's Avatar
Its doable but you just gotta be careful if your useing a column shift. The linkage will hit the bottom of the booster if you dont put it in the right spot.
tonypaul is offline   Reply With Quote
Old 01-09-2011, 12:29 PM   #10
turbotravis
think you have enough motor in that truck?? where did you get those headers? i was thinking of putting a big block in mine but couldnt find a set of big tube headers and didnt want to build a pair...
Old 01-10-2011, 01:59 PM   #11
Fitz
They are Sanderson BB4's. Almost perfect fit. One very small (1/4 inch) half moon on the upper frame rail on passenger side to clear cylinder 4 tube and relocated oil filter on drivers side.
