Old 04-25-2009, 02:23 AM   #1
chevlwb68
chevlwb68's Avatar
Wood Bed Advice
Sorry, I am sure this has been covered a million times.
I need to do my wood bed in my 68 longbed. Does anyone know the exact measurements of each board? Or is there a guide book out there somewhere I can pick up? I know the boards are 3/4" think, but they are different widths and I am not sure on the exact length to fit in the longbed properly. Also, I only finding 1'' thick boards at my local Lowes and Home Depot. Will that thickness work?
Just seems like I could do this for a lot cheaper than buying a pre-cut wood kit. They are so expensive. I have a shop and all the proper tools.
Or does anyone know where to get a killer deal on a pre-cut wood kit that will not kill me on the shipping?
Thank for any help!
-mgf-
1968 Chevy LWB.
Lowered.
15x7 rallies and BFG's.
Built 350.
Dual Flowmasters.
Fast and Loud.
chevlwb68 is offline   Reply With Quote
Old 04-25-2009, 03:28 AM   #2
OhioDan
OhioDan's Avatar
Thumbs up Re: Wood Bed Advice
GMC Pauls has that info. Here's a link. Hope this helps?
http://www.gmcpaulstruckparts.com/47...dWood_Info.htm
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline   Reply With Quote
Old 04-25-2009, 01:32 PM   #3
chevlwb68
chevlwb68's Avatar
Re: Wood Bed Advice
Awesome! Thank you.
-mgf-
1968 Chevy LWB.
Lowered.
Built 350.
Dual Flowmasters.
Fast and Loud.
Old 04-25-2009, 02:50 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Wood Bed Advice
do u gotta take the bed off to replace steel floor with wood?
John
1999 Toyota Tacoma 4x4
Old 04-26-2009, 02:09 AM   #5
chevlwb68
chevlwb68's Avatar
Re: Wood Bed Advice
dunno know. i would guess that it is easier to cut out the metal floor with it removed, but I am sure you could do it without removing the bed.
-mgf-
1968 Chevy LWB.
Lowered.
Built 350.
Dual Flowmasters.
Fast and Loud.
Old 05-25-2009, 09:20 PM   #6
fishingjred73
fishingjred73's Avatar
Re: Wood Bed Advice
If you have the tools find someone local with a sawmill and have them saw you some lumber. They can cut whatever thickness you want and it's cheaper than lowes, etc. White Oak is about the best as far standing up to the elements.
James
'68 Stepside (ground up in progress)
My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html
'81 SWB "Pap paw" (Driver)
The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html
Member of
www.louisianaclassictruckclub.com
https://www.facebook.com/groups/296290610747732/
fishingjred73 is offline   Reply With Quote
Old 05-25-2009, 09:55 PM   #7
westofb
I really hate wet sanding!
westofb's Avatar
Re: Wood Bed Advice
Thank for any help!
The boards you are finding at lowes and home depot are 3/4" wide. I know they are called for instance a 1 x6" but they are actually 3/4 x 5 1/2. The one by measurement is what the board measured from the saw mill prior to thickness planing.
westofb is offline   Reply With Quote
Old 05-25-2009, 10:09 PM   #8
redbaron69
redbaron69's Avatar
Re: Wood Bed Advice
if you have the shop and the tools, i would look around and see if i could find some old lumber like from a barn and resurface it. yes it would be a job,but i have seen this done a few times and that old lumber looks great!
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 05-26-2009, 02:24 AM   #9
vegaschevy
Re: Wood Bed Advice
good seeing this, I am wanting to do a wood bed floor on my truck when i find one.
vegaschevy is offline   Reply With Quote
Old 05-26-2009, 09:56 AM   #10
Willys47
Willys47's Avatar
Re: Wood Bed Advice
I have a wood floor on my Box that was rotted bad.I took a better looking piece of the floor to the local wood store that I had cleand up and it was cut from Douglas fir. Now my truck was built in Oshawa Canada.So what was the types of wood was used back in the day or did they just use wood that was good & easy to get a hold of ?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-26-2009, 10:15 AM   #11
HuggerCST
HuggerCST's Avatar
Re: Wood Bed Advice
If you use GMC Paul's measurements to groove your own bed wood, just remember that those measurements are taken from factory cut boards with GM metal strips. I found out the hard way that my aftermarket stainless strips are not as wide and don't fit as deep into the groove as the originals, and I had to re groove my boards.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 05-26-2009, 11:54 AM   #12
vegaschevy
Re: Wood Bed Advice
is it possible to buy bed pieces reasonable without having to have an entire bed if you are going to lay a wood bed floor?
Old 05-26-2009, 12:32 PM   #13
HuggerCST
HuggerCST's Avatar
Re: Wood Bed Advice
Yes, but it's not cheap. You'll need the wood, metal strips, bolts, a set of cross sills, and a front bed panel. The bedsides and wheel wells are the same for a wood or steel floor.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
