03-23-2018, 06:59 PM | #1 |
Need advice on clutch setup
Ok so I have a 65 c10 with a 1965 corvette 327 motor and a Th350 automatic transmission. I am wanting to convert the automatic transmission to a 4 speed muncie. What will i have to do to change it over. I have a clutch pedal assembly from another donor truck already. I am thinking i will need to purchase a clutch and pressure plate. Do i have to purchase a different bellhousing also? What else i am missing/
Pat |
03-23-2018, 08:10 PM | #2 |
Re: Need advice on clutch setup
you will need a bellhousing...you'll probably also need some driveshaft work...and possibly the trans crossmember...you'll need all the linkage with the pedal assembly. .clutch bellcrank ..pivot ball stud...make sure your frame has the bellcrank mount on it...
03-23-2018, 08:25 PM | #3 |
Don’t forget the pilot bushing.
And a shifter that clears your seat. |
03-23-2018, 08:41 PM | #4 |
Greg
What does the bellcrank mount look like? Pat |
03-23-2018, 09:02 PM | #5 |
mac..It should look similar to this....from the factory they're riveted to the frame...sometimes they're broke or get cut off by po's...will be inline with the rear of engine under
03-23-2018, 09:05 PM | #6 |
AHHHHHH thanks. I don't think I have those. Need to add it to the list. Thanks.
03-23-2018, 09:07 PM | #7 |
Greg
Where did you get that picture of the bellhcrank mount from? Pat |
03-23-2018, 09:09 PM | #8 |
03-23-2018, 09:10 PM | #9 |
look before you buy...it may be there...that one is for a 73-87..
03-25-2018, 09:25 AM | #10 |
So i picked up the Muncie 4 speed. it came with the shifter and arm attachments, a new clutch and the 67 camaro bellcrank bracket pedal assembly. I bought a bellhousing off of e-baaaaaay from big city corvettes that should work. I will need to purchase a new flywheel, pilot bearing and shifter stick. What else am i forgetting. Oh and thanks for your help your advise and information is so very helpful.
Pat |
03-25-2018, 09:56 AM | #11 |
will a camaro bellcrank work on the truck?...I can't picture them being the same
you'll need a clutch fork as well...and pivot balls...and you said new clutch so I assume its got a pressure plate with it...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-25-2018 at 10:02 AM. |
03-25-2018, 10:05 AM | #12 |
You’ll need to check the size of your clutch and get a flywheel to match. Not all flywheels are drilled for both sizes.
Also you need to match your starter to the new flywheel. |
03-25-2018, 11:07 PM | #13 |
60-66 Nut
You can not use a Camaro clutch bellcrank in your '65 truck. You have to have a bellcrank specifically for the '63-'66 trucks as well as all of the other clutch linkage. Plus you will need the ballstud that screws into the block in the forward location. What exhaust manifolds or headers are you running? Not all of them are compatible with a '63-'66 truck running a manual trans. Also is your engine mounted in the correct original location for a small block? If not none of the factory clutch linkage assembly will work.
03-26-2018, 12:21 PM | #14 |
Sounds like a cool engine option. I'm cloning a '70 Corvette motor for my '70 C10.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
03-26-2018, 05:31 PM | #15 |
I bought the original bellhousing for that vette engine. I also purchased all of the other clutch linkage. The bellhousing takes a 10.5 clutch and pressure plate so I think I will need tpo purchase them along with the correct flywheel. Is that correct?
