Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-01-2019, 08:39 PM   #1
dennislbrooks
dennislbrooks's Avatar
80 amp relay on 1 wire alternator
Has anyone used a 5 pin 80 amp relay to break the one wire alternator connection to the battery when the car ignition is Off?
I have a one wire 60 amp alternator 10si on my 59 GMC. I go 3 wire alternators now.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 12-03-2019, 06:02 AM   #2
SunSoaked
SunSoaked's Avatar
Re: 80 amp relay on 1 wire alternator
Curious what the purpose would be?
SunSoaked is offline   Reply With Quote
Old 12-03-2019, 09:57 AM   #3
dennislbrooks
to kill the 35 milliamp continuous draw when ignition off
Old 12-03-2019, 10:08 AM   #4
SunSoaked
SunSoaked's Avatar
Is this a common problem to all one wire alts? So, is there a module (Exciter) inside the alt that pulls this small current? I've never heard this. I never liked the 1-wire I had cause of having to rev the engine once to excite it. I ended up tossing it in the trash. Went CS 130 and never looked back.
Old 12-03-2019, 10:24 AM   #5
dennislbrooks
As I understand yes, one wires will pull .003 amps or less with alt hooked up, key off, measuring from battery negative to positive cable off battery. And that is for a good one.
I agree going forward I only get 12si's or better with 3 wires controlled with ignition switch.
I will try the relay and let you know just for grins.
Old 12-03-2019, 10:37 AM   #6
Andy4639
Old member
Andy4639's Avatar
Question Re: 80 amp relay on 1 wire alternator
That would take a very long time to kill a good battery for normal use though. if you let it sit more than you drive it then why not just put a trickle charger on it and call it good. Better yet go back to the 3 wire setup which is better anyway.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-03-2019, 11:09 AM   #7
dennislbrooks
I won't argue that, but I have a 1 wire that I will use until it dies.
Old 12-03-2019, 12:05 PM   #8
vince1
I would only alter the wiring with relays for more important stuff like headlights or electric fans. Why not just put it on a trickle charger if the vehicle is not being used for a while? I've got the same problem BTW with a small drain that I think is coming from the newer style radio.
vince1 is offline   Reply With Quote
Old 12-03-2019, 02:18 PM   #9
dennislbrooks
I know that some radios have memory and will have a slight draw. Same with security type items. And I do run trickle chargers. This is the only 10si I have and because the alternator has no memory to keep voltage on, I will kill it with key off. Relays are somewhat cheap.
I thank you guys for your input.
Old 12-10-2019, 11:23 PM   #10
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
That is not an important draw. For BMW, which I've ben a master tech for 10 years now and the draw spec is around 40 miliamp. If you have a draw problem, it's not 35 milliamp
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 12-11-2019, 12:01 PM   #11
Bigdav160
Bigdav160's Avatar
35 milliamps will draw down a battery to the point the vehicle won't crank in less than 4 weeks. (depending on reserve capacity rating)
But 35 milliamps isn't .003 amps. Which is it?
I have a one wire alternator on my boat. It came that way from the factory. I haven't noticed any parasitic drain so I haven't bothered to measure it.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-11-2019, 12:08 PM   #12
87chevy.com
I would say the solution is to use trickle charger on a vehicle that sits that long instead of the relay thing.
Old 12-11-2019, 08:26 PM   #13
dennislbrooks
.003 amps or less draw is normal on a 10si 1 wire alternator with igniton off from my research
