Old 11-23-2002, 06:54 PM   #1
Stirdr
Question Newbie with a fuel line question
I am attempting to resurrect a '72 Blazer that has been severly abused. I am new to the gear-head life - but I am adventurous!!! The Hillbilly owner before me had a *small* engine fire and installed a new crate 350. After copious ammount of duct tape and solder - he got it to run and sold it to me. I am almost complete in getting it road worthy - rewire, repaint, sacrifice to the God of BowTies... I am tracing lines from the tank - one goes to the pump up front, one is the filler hose, one goes to the sleave around the filler hose, and two join another and go into this sealed tube that is located in the rear driver side cargo panel. From that tube I follow a metal line to the engine and then....nothing. It just hangs there - waiting to be connected to something. Any ideas????
...here for a good time...not here for a long time...
Working to repair what some hillbilly did to a '72 K-5
Stirdr is offline   Reply With Quote
Old 11-23-2002, 08:01 PM   #2
meathead95
computer illiterate
meathead95's Avatar
I have never had a blazer, and you lost me on the line thing. but welcome from Nashville. do you have any pics?
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-23-2002, 08:21 PM   #3
da-burb
"Ochre Ogre"
da-burb's Avatar
That is part of the emissions system. In 71 GM went to a non-vented cas cap. On warmer days gasoline will tend to give off more vapors. The 2 lines that join into one are vent lines on the left and right of the gas tank. The cylinder is an expansion chamber / liquid trap. The line that is just hanging there should go to the charcoal canister that is between the battery and the fender. From the canister you will have a hose that "T's" to the PCV hose. This will pull any vapors out of the charcoal canister and burn them as you drive.
It is up to you if you want to put it back to factory. Since it doesn't hurt milage or performance I guess I would.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 11-23-2002, 08:31 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Oh. and I forgot the most important thing, WELCOME from Minnesota!
Old 11-23-2002, 08:47 PM   #5
dashadow
Welcome from Alabama. Duct tape and solder? Man you have got to post some pics! Good luck 2 ya.
'71; 250; 3 on a tree GMC
dashadow is offline   Reply With Quote
Old 11-24-2002, 01:14 AM   #6
Ackattack
Ackattack's Avatar
yeah, charcoal canister. I removed mine a few years ago. I wouldn't worry about it.
And WELCOME!
Ackattack is offline   Reply With Quote
Old 11-24-2002, 10:43 PM   #7
Stirdr
Talking THANKS!!
Thanks for all the info! It helped clear up a few things. I will get the camera out this weekend to post a couple of recent pics. I have some shots of the "gifts" I found....never seen duct tape, wire nuts, and solder all used on the same circuit.
From Idaho....
