01-04-2024, 06:23 PM | #1 |
Quick window regulator question
My window cranks have about 22.5° slop from up and down direction. Both my cranks have it.. inspection of hardware looks good. Is there normally that much give between rolling up and rolling down? Thanks for help.
01-04-2024, 07:51 PM | #2 |
Re: Quick window regulator question
Do you mean the windows tilt by 22.5 degrees? I believe that is not normal for them to tilt at all. I suggest remove the inner panel and inspect the window regulator. They are supposed to have the plastic rollers in the tracks. There are certain spots in the track where the roller can be inserted, otherwise they stay in the tracks when the window is rolled up and down.
01-04-2024, 08:26 PM | #3 |
I'm pretty sure he means the window cranks rotate that much without moving the window. That does seem a bit excessive.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
01-04-2024, 08:32 PM | #4 |
No I am referring to the rotation of the crank handle. The tracks and wheels are all in very good condition with no apparent play of significance. The play seems to be in the crank gears. It has been decades since I have owned a manual window. I cannot recall how much play was in the handle back in the day. I have no problem replacing the regulator but from what I can tell the play in rotation of the window crank handle is normal. I am just looking for confirmation.
01-04-2024, 08:49 PM | #5 |
I have that much free play in the crank, and my window works fine and I never noticed it before you pointed it out.
01-05-2024, 10:50 AM | #6 |
Moderator
If it functions as it should I’d leave it alone
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-05-2024, 11:01 AM | #7 |
There's no doubt it probably has some wear, but if it still works...it still works
I have a brand new NOS regulator....I'll check to see how much backlash it has Update: 10º-15º backlash before engagement and movement
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. Last edited by A1971Blazer; 01-05-2024 at 11:10 AM. |
01-06-2024, 12:21 PM | #8 |
Thanks for input. Above info gives me a reasonably good feeling the play in handle is close to normal. The tracks and rollers are clean with no grease and still function very well when the widows is properly controlled. The fuss in the guide tracks is very bad shape and allow window to rack and bind some. If I control window it rolls up and down smoothly. I plan to rebuild the vent windows and replace all rubber and fuss. I think the result will be good.
01-07-2024, 08:39 PM | #9 |
Maybe mine are worn out but both driver and passenger sides have at least 22 degrees of free movement when changing direction. That's only 1/8 turn, seems reasonable to me.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
01-08-2024, 01:31 PM | #10 |
I installed NOS everything of late. Like post 7, the cranks engage approx. 10°, basically a click.
If it's a driver, then if they aint broke don't fix em?
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
