11-23-2020, 05:16 PM | #1 |
Video - C10 Cowl Cleaning + Old Air Products Cowl Grills
The video below shows how I cleaned out my '71 C20 cowl. There was quite a bit of debris packed right up to the floor vent. It's important to clean this out once in awhile to keep rust from forming. GM failed to put a grill or screen on the outside cowl panel and any leaves, seeds or dirt will end up at the low spot of the cowl air intake.
To prevent recurrence, I installed some Old Air Products cowl grills (p/n 50-7236B). These are decent for the money and I'd recommend using them. Here's the video: https://www.youtube.com/watch?v=SFr7TsNVrvc
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs Last edited by bry593; 11-23-2020 at 07:11 PM. |
11-23-2020, 06:27 PM | #2 |
Re: Video - C10 Cowl Cleaning + Old Air Products Cowl Grills
So, did you finish the job?
The rubber on the vent doors need replacing. drill out the tiny rivets on the door(s) and replace the rubber with new rubber material that is about 1/2' wider on all sides, except a little shorter top/bottom. Hardware stores sell the rubber material in sheets. If you can find some reinforced rubber sheets that is flexible enough, it will last longer.
'67 GMC 2500, 292, 4spd, AC |
11-23-2020, 06:35 PM | #3 |
11-23-2020, 07:05 PM | #4 |
Just realized I forgot to mention, there are HVAC doors at both sides folks. The passenger side is very similar to the driver's. You need to clean both out.
No, didn't bother riveting or stapling any new rubber to the fresh air vents. Not worried about it. Pick your battles as they say.
1971 C20 Custom Deluxe, HT383, 4L80E, 3.73 Locker, 4 Wheel Discs |
11-23-2020, 07:50 PM | #5 |
11-23-2020, 09:29 PM | #6 |
I feel your pain. My air ducts were full to the bottom of the doors. The passenger duct had rotted out bottom so I had to make a new one. Not had just a bit of a PITA to get the radius right.
I got some black gutter screen from a local home improvement store so I can make my own cowl screen.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
11-23-2020, 09:49 PM | #7 |
i used the lmc screens seems the holes are too small . theres a huge loss in air flow with them in . i like having them open when its hot out
11-23-2020, 10:04 PM | #8 |
Old member
I use screen porch screen it's cheap. I also bought new doors for the kick panels.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-23-2020, 10:31 PM | #9 |
When I brought my 68 home it came out the CA high desert. The cowl and vents were packed to the top with pine needles and mouse and rat nests.
I pulled the vent doors out and cleaned every thing out. The seals on the vent doors were all but gone. So because I'm cheap I went down to the local tire shop and they gave me an bad truck inner tube. I made the new door seals out of the inner tube. Cost me nothing. |
11-25-2020, 09:41 AM | #10 |
One thing I did while I had the front clip off was take a hole saw and enlarges the cowl drain enough that acorns wouldn't clog the system, plus I put in a cowl screen too.
11-25-2020, 11:06 AM | #11 |
With the cowl screens, I don't believe anything will ever block the drain again. Well, maybe if you park under a pine tree or something like that. Funny the way people think they are protecting their vehicle by parking under a tree. You'd be much better off parking out in the rain and sun.
12-01-2020, 10:03 PM | #12 |
Any advice on how to clean up this mess?
Prior owner had glued a vinyl covered piece of cardboard over the kick panel and vent. I assume to cover up the metal that had been eroded by rust and debris. Not up for a full teardown and metal repair at this time. I'm thinking about just getting the abs kick panels and reproduction vents from LMC and doing my best to get them to fit and stay in place.
72 C10 Cheyenne Super |
