Old 01-04-2021, 02:37 PM   #1
DA68
Trailing Arms Needed in NE Ohio
Hi. Helping a friend with his 67 GMC and wanting to convert to trailing arm suspension. We need a nice set of trailing arms, but could also use the cross member trailing arm brackets and a coil spring rear end. Thank you and please PM me if you have some of these items.
DA68 is offline   Reply With Quote
Old 01-04-2021, 08:03 PM   #2
MeanGreen72C10
Active Member
MeanGreen72C10's Avatar
Re: Trailing Arms Needed in NE Ohio
I'm converting to a GSI back-half in the coming months. I have brand new trailing arms and will have the cross-member, brackets, lowering springs, blocks, u-bolts.. may convert to a 9 inch while I'm at it.. if so I have a just rebuilt 3.73 rear end (one wheel peel)
I live just north of Detroit.
MeanGreen72C10 is offline   Reply With Quote
Old 01-04-2021, 11:19 PM   #3
DA68
Sounds good. PM me what you might ask for the whole package. Thanks.
Old 01-06-2021, 06:50 AM   #4
DA68
Bump
Old 01-26-2021, 10:33 PM   #5
DA68
Found some. Thanks.
