01-26-2020, 11:46 AM | #101 | |
Re: 85 C10 LT/6L80 Frame off build
01-26-2020, 11:21 PM | #102 |
Looks clean. Hard to beat a clean satin black/SS combo.
01-31-2020, 09:45 PM | #103 |
Such beautiful work and so inspiring. Also, what kind of lighting do you have, because it looks color-balanced, which helps when viewing things "correctly?"
01-31-2020, 11:57 PM | #104 |
Really nice build...oh so clean...
02-02-2020, 11:01 PM | #105 |
Thanks! Nothing special, I’m just getting lucky with lighting I guess. I have a really bright garage with LED ceiling lights and grey walls and floor.
02-02-2020, 11:02 PM | #106 |
02-02-2020, 11:36 PM | #107 |
Lots of updates in the next few pics, finally got around to getting it painted. I used Tamco basecoat and clear, pretty happy with the results, it had been about 4 years since I had sprayed a vehicle. I remember why I quit! once painted I let it rest in the heat for about 3 days and then started sanding the clear. I used 800,1000,1500,2000,3000,5000,8000 water paper and when finished I had a nice semi-gloss finish that was fairly easy to buff out to a great shine.
02-02-2020, 11:48 PM | #108 |
vintage air going in and that awesome looking Dewitts radiator
02-03-2020, 09:40 PM | #109 |
Beautiful truck, before and after. Probably more money there in brakes, tires, and wheels than I have in my entire truck! More power to you.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
02-04-2020, 10:40 AM | #110 |
chevy truck fan
luke,
Nice progress and a great eye for the little things. I was wondering if you have any pics of the firewall after the V.A. install? I would be interested in how the lines look going through the firewall? also how smooth did the install for the unit go for you? |
02-04-2020, 09:15 PM | #111 |
02-04-2020, 09:29 PM | #112 | |
02-04-2020, 09:37 PM | #113 |
inside of bedsides and wheel tubs cut and buffed, I doubt ill cut and buff the floor. starting to look like a truck, cleaning all the buffing compound out of every crack before installing trim and bodyside molding. got the fuel tank vents installed with some simple brackets I made hidden up in the bedsides.
02-05-2020, 04:02 PM | #114 |
chevy truck fan
luke,
THANK YOU!! exactly what I was wanting to see. My install looks very close to yours , but not near as clean. I know what you mean about a pair of hands. my nieghbor came over to lend a hand to hold the lines while I installed the hoses (wife tried)-but I was too strong for her... Curious: did you use the plate on the firewall due to factory wall "thinness"? The pics also confirmed my heater line connections, I was not sure which lines connected to the LS motor?. lastly what "vent" are you using for the gas tank(s)? If willing to share? I might try to copy the idea as well?? Thanks!! |
02-05-2020, 10:22 PM | #115 | |
the fuel tank vent is sold by Holley part #19-174 I made a bracket and used one on each fuel tank. |
02-05-2020, 10:30 PM | #116 |
Earls Ultra-Pro trans cooler installed along with a power steering cooler.
Time for some interior work, I picked up carpet and lower door carpet from ACC, they have the OE colors and an excellent fitting product. |
02-05-2020, 10:37 PM | #117 |
one thing I knew I wanted was a nice modern sound system that fits like factory and no sub box behind the seat. I went full Memphis for factory size speakers with a 200 watt amp for highs and a 10" powered Memphis sub for under the seat.
02-06-2020, 01:33 PM | #118 |
Your Truck looks extremely good - this is a top quality build!
2 questions - on the paint lines for the 2 tone cab roof - I'd be curious if you could show some pictures of where you made the tape line (I'm thinking of a white roof and don't have any examples of where the paint dividing line should be). 2nd question - those front dash speakers look nice - have you tried fitting the dash yet? I'd be interested if they fit without hitting the dash pad. I put some aftermarket ones in (different brand) and they were too tall. |
02-07-2020, 10:05 PM | #119 | |
I did have issues with the speakers, I had forgotten until you asked. I ended up buying another set of Memphis 3.5” that the center didn’t stick out on. |
02-10-2020, 08:38 PM | #120 |
Looks great Luke! Keep up the good work!
02-11-2020, 10:28 AM | #121 |
chevy truck fan
Luke,
Enjoying the updates... was wondering if you have a pic or two of the area around the power steering connections? I am in the process of trying to run the pwr steering lines along the brake lines & not sure "the order" that the lines go in? IE: the brake lines over/under the power steering lines.... if too much trouble or time, no worries..... a really beautiful truck!!!! |
02-15-2020, 05:08 PM | #122 | |
02-15-2020, 05:15 PM | #123 | |
02-15-2020, 05:53 PM | #124 |
So.... What happened to drive the fan/shroud switch-a-roo?
02-15-2020, 10:12 PM | #125 |
The last pic is the fan/shroud that Dewitts uses. It works fine as I’ve used that combo before. I wanted the shroud to cover the entire radiator and some super powerful fans in case I ever need them. I also wanted a shroud that would bolt onto the OE radiator top plate.
