Old 01-18-2021, 12:16 PM   #26
Asshat
Asshat's Avatar
Re: Front suspension and steering questions
Originally Posted by bigmoe View Post
When you have a lean like that it could be caused by the front or back springs. What you can do is, with the truck on a level surface, put the front frame level on jack stands and see if the rear if off. Then do the same thing with the rear frame on jack stands to see if it's the front where the problem is.
Ok, I think I’ll try this.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 01-18-2021, 04:34 PM   #27
Asshat
Asshat's Avatar
The distance from the frame to the top of the axle is 1/4” less on the driver side. Not sure if this would make a difference of 1-1/2” when sitting on the ground.
I wonder if the pan hard bar could affect this?
292, 4-speed
Old 01-18-2021, 05:47 PM   #28
SCOTI
SCOTI's Avatar
Put something under the tires if you need the room (I use pieces of 10x10x2 wood stacked as necessary) & have full weight for your measuring. It shouldn't but can make a difference.
1/4" is not going to translate into 1.5" on the opposite end. That dimension is within 'standards' of a vehicle corner height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-18-2021, 06:00 PM   #29
Asshat
Asshat's Avatar
The measurements I took was with the truck on jack stands, and the axle just hanging.
292, 4-speed
Old 01-18-2021, 06:24 PM   #30
Asshat
Asshat's Avatar
More info.
I think it is the way the spring sits in the retainer. Is this spring retainer intended to be
positioned a specific way?
292, 4-speed
Old 01-19-2021, 03:51 PM   #31
Asshat
Asshat's Avatar
Do those springs look too collapsed with the truck just sitting on the ground?
And, will 1/2 ton springs work on a 3/4 ton truck? I am not planning on carrying heavy loads, just normal driving around town.
The Truck and Car Shop in Orange only lists springs for 1/2 ton pickups.
292, 4-speed
Old 01-19-2021, 04:03 PM   #32
SCOTI
SCOTI's Avatar
1) Do those springs look too collapsed with the truck just sitting on the ground?
2)And, will 1/2 ton springs work on a 3/4 ton truck? I am not planning on carrying heavy loads, just normal driving around town.
1) Yes, they do.
2) Yes, they do.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-19-2021, 05:41 PM   #33
bigmoe
bigmoe's Avatar
Those springs do look pretty collapsed. I'd be worried it would sit too high if you bought new stock springs. A lot of guys (including me) use 97-06 Jeep TJ rear coils as drop coils on 1/2 tons. (ACDelco 45H2104)
bigmoe is offline   Reply With Quote
Old 01-19-2021, 06:03 PM   #34
Asshat
Asshat's Avatar
What drop do these provide for a C10 pickup?
2” maybe??
292, 4-speed
Old 01-19-2021, 06:22 PM   #35
bigmoe
bigmoe's Avatar
4" I believe. And I see in my notes the ACDelco 45H2104 is a 653lb variable spring.
Old 01-19-2021, 06:54 PM   #36
Asshat
Asshat's Avatar
I read a couple posts about those springs, people complaining of spongy ride. Not sure if that’s accurate. I wasn’t planning on a 4” drop - is that just the rear, or 4” drop for the front too?
292, 4-speed
Old 01-19-2021, 07:20 PM   #37
bigmoe
bigmoe's Avatar
Mine is 2 1/2" drop spindle front with stock springs, 4" drop in back with those Jeep springs. It's a short fleet and the back is very stiff. I still want to try to loosen it up with some different shocks but that will be after I get it from storage in the spring.
There is also a heavier Jeep spring. The ACDelco 45H2103 and the Moog 47939GB are 821lbs variable.
One of my biggest complaints about my truck is the poor (clunky/stiff) ride. The other complaint I have is not enough leg room.
Old 01-19-2021, 08:21 PM   #38
Asshat
Asshat's Avatar
I think I’m just going to go down to the Truck Shop and see if they have the 2” or 3” drop springs for the rear. At least those will fit and all I have to do is get the right drop. The Jeep springs are not a sure thing, and if they are 4” drop that’s probably too much for what I want.
292, 4-speed
Old 01-20-2021, 09:57 AM   #39
Railroadman
Railroadman's Avatar
The truck sits pretty nice, I think. A while back, I was thinking about dropping it a couple of inches.
If I do buy new springs, you think I should go with 2” lower front and rear?
That's a question you will have to decide for yourself - we all have different likes and dislikes.
Since you ask the question, people have been lowering vehicles since long before most of us were born. That said, I have never liked the lowered or slammed looks. The lower something sits, the more it looks to me like it's broken. I guess I'm more of an "original" guy.
Again I'm not saying lowering is "wrong", just that to my eyes the truck looks more normal at standard ride height. YMMV.
Railroadman is offline   Reply With Quote
Old 01-20-2021, 11:38 AM   #40
Asshat
Asshat's Avatar
I’m not certain, just guessing that if my springs are collapsed, I’m already at a 2” or 3” drop. The truck does not look slammed, so if I can keep it about the same, I’ll be happy.
292, 4-speed
Old 01-20-2021, 06:29 PM   #41
Asshat
Asshat's Avatar
I looked in the manual and it shows a notch should be aligned with the end of the spring. Not sure if the end of the spring should be facing in or out? Anyone have an idea?
On the passenger side, the spring was not removed, so it seems the driver side spring was incorrectly installed.
Has anyone installed these before? Can you confirm the notch is on the spring retainer?
292, 4-speed
Old 01-20-2021, 06:49 PM   #42
SCOTI
SCOTI's Avatar
It doesn't matter.
Just clock the springs the same on each side & install the retainers similarly @ each side.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-22-2021, 10:42 PM   #43
Asshat
Asshat's Avatar
I installed stock height, new coil springs in the back and got a new track arm (pan hard bar). I think it sits more level than before. Rides a lot better too. Next step is to replace the front springs and ball joints.
Also going to list some 2” drop springs; these did not work out for me. Couldn’t get the wheels mounted, tires a bit too wide.
292, 4-speed
Old 01-23-2021, 12:23 AM   #44
cwcarpenter98
cwcarpenter98's Avatar
How's your cab and core support mounts lookin? If they are blown out, that could also make it look like it's leaning
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 01-23-2021, 12:54 PM   #45
bigmoe
bigmoe's Avatar
I have a similar problem (made even worse because the short box has a smaller wheel opening). Solved it by jacking the truck up by the frame so the suspension is in full droop. That gives room to remove/replace the tire.
Old 07-28-2021, 10:54 PM   #46
Asshat
Asshat's Avatar
Well, the truck is still leaning to the driver side. Measured at the rear bumper it is 1-1/2" lower on the driver side. I may need to jack it up at the frame and loosen the springs and see if I can rotate them to get it to sit evenly.
Maybe that will work.
292, 4-speed
Old 07-29-2021, 07:27 AM   #47
The Rocknrod
Moderator
The Rocknrod's Avatar
Looking at the a-arm space when seeing the front of the truck, that's what I'd look at also.
