06-17-2019, 04:53 PM | #1 |
Differential Question
Haven't been able to find out what I have here and code on axle not readable.
06-17-2019, 05:00 PM | #2 |
Re: Differential Question
Open diff (not posi) there will be numbers on the edge of the ring gear (big one), divide the second number by the first. Example. 11:41. 41/11=3.73 gears
06-18-2019, 10:09 AM | #3 |
count the teeth on the ring and pinion if you can't read any of the numbers.
06-18-2019, 05:34 PM | #4 |
driven gears (ring) divided bye drive gears (pinion) = gear ratio
06-18-2019, 07:25 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
That's a GM "Truck 12-Bolt" A mighty clean one!
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
06-18-2019, 07:30 PM | #6 |
X2 on the GM 12 bolt truck rear end
06-18-2019, 11:02 PM | #7 |
The edge where the green spot is in the first picture is where you'll find the stamped numbers.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-19-2019, 06:22 PM | #8 |
TYAVM for help.
