03-18-2019, 05:01 PM | #1 |
72 crew cab project with lots parts
Up for sale again, long short story.
Quick description, have a clear 72 c20 longhorn super camper special, vin with title in my name. The best way to see its current progress is look at the build thread in my signature. Have 98% of the metal to finish it minus the clip. Front clip was trash and long gone. All the cab/metal parts without the suspension $1500 which includes another B-pillar and everything to finish the 4th door. The reason for no suspension is I need the 4wd rear spring hangers and 4wd front setup for my other truck The rear axle can go with it, have another eaton housing also that can go Have the 72 ac cab half that has the firewall, windshield frame, complete floor still intact I even have a 67 cab That has the dash cut out I’ll let go too if you want it. Have a crew cab square body harness I was going through to use on it as well that can go with it, half of the door channels I should have, I think there are also 2 pair of inner/outter window felts/sweeps. Basically anything I have that I won’t use on my other regular cab it will go with the crew. Some body side upper and lower moldings and front fender spears.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 04-01-2021 at 09:25 PM. |
03-18-2019, 05:22 PM | #2 |
Re: 72 crew cab project with lots parts
72 burb with bill of sale and inspected vin by Athens-Clarke county, 72 A/C cab with bill of sale for the rear and the front cab and floor intact to use to repair rust on the front half of the burb. Burb floor is solid in the center but rusted around all edges so I was gonna just replace the whole front half as one piece.
List of parts as follows: Wheels your choice of 20x9 on chassis now with half worn 35x12.50 toyo tires or procomp 18x9s with almost new 33” A/T tires on my red truck 3” billet wheel spacers Passenger doors currently on burb rust FREE with all hardware driver door someone shaved but In good condition(partial guts) All 3 original doors complete with working internals Another set of 3rd door hinges, relay rods, latches(to build 4th door) 157” wheelbase frame that I cut the rear horns after the crossmember/spring mounts for a short wheelbase but still have them if you wanted a longbed Square body 4wd engine crossmember and engine mounts Decent longbed to shorten, not a rust bucket but will need some work Front springs are skyjacker 4” for rear(52” front spring swap) Front sway bar and axle drop down brackets DIY4X 4wd spring hangers(fronts still on my other truck) Crossover steering with pitman arm, core power steering box, all linakge(came off my other truck) New rear ubolts Front cab half from the 72 donor with solid floor unbolted and uncut Cab light roof with what looks like something fell on it, skin easily repairable after separated from the rest of the structure. Front axle is a 90 model 10 bolt with all Dana 44 parts from the balljoints out, new balljoints, rotors, calipers, pads, bearings, warn reseal/hardware kit still in bag Brand new LED tail light assembly’s All tail and reverse buckets
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 01-14-2020 at 04:07 PM. |
03-18-2019, 05:30 PM | #3 |
Miscellaneous factory exhaust hangers ive been collecting
Enough trim to do the whole truck minus upper bed Taillight & tailgate trim A couple of repair panels Bed taillight cut 72 only west coast jr mirror brackets Suburban roof cut in two sections low enough to fill in the roof for the crew cab 4th door area carefully cut from burb to be reused for building a door
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 01-14-2020 at 04:03 PM. |
03-18-2019, 05:40 PM | #4 |
Burb body and cab
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
03-18-2019, 05:43 PM | #5 |
Roof removed by spot welds, 4th door skin cut with extra length to use on 4th door
03-18-2019, 05:48 PM | #6 |
Cab back just sitting there, 4th door window frame, truck cab floor in very good condition
03-18-2019, 05:51 PM | #7 |
72 truck cab, front axle
03-18-2019, 05:54 PM | #8 |
Door jamb area, repair panels, taillight cut
03-18-2019, 05:57 PM | #9 |
Bottom of near perfect passenger doors, 4th door cut, shaved driver door, west coast Jr brackets
03-18-2019, 06:08 PM | #10 |
Roof and 4wd mounts
When I got to the driver side I realized if I rotated it one hole lined up perfect with the cab mount hole, that’s why it isn’t the same angle as the passenger
03-18-2019, 06:13 PM | #11 |
Chassis, 20” wheels, cut rear frame for shortbed but horns still there so could be put back to mount a long bed. 18 wheels currently on my driver
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 03-20-2019 at 12:20 AM. |
03-18-2019, 06:16 PM | #12 |
Roof sections, burb parts, front clip
03-18-2019, 06:21 PM | #13 |
5” rear diy4x shackles, sway bar, front spring hangers
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 01-14-2020 at 04:04 PM. |
03-18-2019, 06:24 PM | #14 |
Engine crossmember & mounts, exhaust hangers
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 01-14-2020 at 04:05 PM. |
03-18-2019, 06:31 PM | #15 |
Lots of trim
03-18-2019, 06:35 PM | #16 |
Reverse and tail buckets, LED tail lights, emblems, (2500 custom and 3500 v-eight pairs sold). Deluxe emblems, single front shock bracket, hell I’ll even throw in the nascar models
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 03-29-2019 at 09:58 PM. |
03-18-2019, 06:38 PM | #17 |
Shock brackets and bump stop brackets
03-20-2019, 12:26 AM | #18 |
Also willing to keep all 4wd related components.
Price would obviously reflect
03-28-2019, 05:05 PM | #19 |
Turbos and cluster that wasn’t in too good of shape have both been sold, take $150 off the top just for that reason.
03-29-2019, 09:25 AM | #20 |
Would you be interested in selling the body, bed, miscellaneous panels, and trim items? I wouldn't really be interested in frame and suspension pieces.
03-29-2019, 03:12 PM | #21 |
Without suspension wouldn’t hurt my feelings as I can use it on my other truck. Pm me your number and I’ll text you. Can call this evening after work.
03-30-2019, 05:55 PM | #22 |
Still up for grabs, willing to separate body from chassis, completely or just 4wd components.
12-12-2019, 12:03 AM | #23 |
For sale again as the same situation as before. I’ll entertain any reasonable offers. I have acquired more parts and done more work. You can look in the build thread in my signature below
12-16-2019, 03:17 PM | #24 |
12-18-2019, 12:45 PM | #25 |
Realized I never updated pricing. The shell I’m asking $2000 with all of the metal to finish it up which includes the title. If you want more than just the shell price will be dependent on what all you’d want
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 12-18-2019 at 12:51 PM. |
