Old 09-30-2014, 10:41 PM   #1
silky
damage to rear axle shaft
A week ago I changed the rear brakes on my 03 Tahoe Z71. Afterwards I noticed an annoying burnt grease smell which I tracked down to the driver side rear wheel. I assumed it was the axle seal so I decided to change the seals/bearings on both sides. My guess was right...the driver side parking brake was covered in gear lube. When I pulled the axles I found some damage on the driver side. There is a thin and rough gouge in the bearing/seal area.
I am attaching a picture.
Do I need to replace the axle? Can I use a "repair bearing"? or is it nothing to worry about?
thanks
silky is offline   Reply With Quote
Old 10-01-2014, 02:47 PM   #2
Bigdav160
Bigdav160's Avatar
Re: damage to rear axle shaft
I would be comfortable using an "axle saver" bearing on that. I recently pulled the axles on my '73 Z28 to find the axle bearing had ate .030 out of the axle. I replace it and the bearing/seal
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-01-2014, 04:07 PM   #3
silky
Thanks for the reply. I think it actually looks worse in the pic then in reality. It seems most of the mark is more of a stain than anything as it is smooth to the touch...only one spot is slightly rough. I think I may try a cheap axle saver bearing and just monitor it.
