02-26-2007, 02:19 PM | #1 |
INfo on front D60's
So, I've found a junk yard with a couple front D60's to choose from. Ignoring gearing, and I'm aware of Single vs Dually fronts, what else do I need to know? Specifically, are there differences in the years that will make it easier or more difficult to adapt to my '69K10?
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
02-26-2007, 02:32 PM | #2 |
Re: INfo on front D60's
go here. it should have all the info your looking for and more
http://www.pirate4x4.com/tech/billav...ont/index.html stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
02-26-2007, 02:32 PM | #3 |
If it`s GM they all bolt up the same to the springs.You can use a Dodge,but spring pads are a tad wider.I believe they are close enough,but moving them would be best way to handle it.
02-26-2007, 05:40 PM | #4 |
Where are all theses dana 60s?If there is more then 1 I will come get a few too
02-26-2007, 07:51 PM | #5 |
K5Camper
Be sure to get the D60 spring plates. They are different than the 1/2 ton stuff.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
02-26-2007, 08:32 PM | #6 |
Only thing that changed on GM 60 are the inner shafts, they went from tapered in 77 to non-tapered around 80-81. Dodge was the same way. Dodge will bolt to the springs, a 1/4" per side isn't really much to worry about. The shocks, u-joint, and brakelines all need to be addressed as they are different between the two. Also Dodge has external lockouts on the early ones, up to late 80s I believe. Ford used 60 in the mid 70s, but weren't all that good. Low pinion, small u-joints, 30 spline inners and small outers. 77.5-79 are the ones to get, spring width is close to GM, u-joint is same most of the time, but still need to look at braklines and shocks. Either aren't too difficult. Ford didn't use a 60 front until 85, but they had the wider pad width, which can be a problem with tires rubbing at full lock. I've messed with them all, so know about them!!!!
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
02-27-2007, 07:02 AM | #7 |
And the FlOoReD axle has the differential on the driver side.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-27-2007 at 11:52 AM. |
02-27-2007, 07:45 AM | #8 | |
K & Zoomad - thanks for the inputs!
02-27-2007, 09:15 AM | #9 |
Personally, look for a Dodge D60...they seem to ALWAYS go cheaper than the GM counterparts. External hubs? Prove to me they're weaker than internals, and maybe I'll start believing it. You will need to change the pinion yoke on one, though.
Whatever you do end up finding, locate the BOM on the axle tube and decode it on dana's website. it will let you know approximate year, original gear ratio, and type of differential (e.g. trac-lok, powr-lok, detroit).
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-28-2007, 08:37 AM | #10 |
I just read over this thread and found no words against the Dodge external hubs.
02-28-2007, 02:11 PM | #11 |
Usually they pop up. I guess I'm paranoid
02-28-2007, 04:36 PM | #12 |
Got a Dodge external hub complex? I think I see where you got that.I`m dislexic and had aahdd(and retarded).The following statement about the Ford hi-pinions?
I agree about the Dodges coming up cheaper for the same axle.I had an`87 W250 and it had a Dana60.Dodge wasn`t selling alot,but these axles came in alot of what they did sell.
02-28-2007, 08:46 PM | #13 |
so...you not gonna say where the d60 front axles are? I need one 2,then it would be 2 69 Blue Chevy 4x4s in Indy with d60 front axles
Sounds like something to experiment with at the Badlands.. |
02-28-2007, 09:10 PM | #14 |
Let me get mine squared away, and I was going to PM you the contact info. The place is about 30 miles north of Lafayette, so I know it'll be a haul. And I'm dying to go to the badlands again, and the g/f is about to go postal on me if I don't take her soon!
02-28-2007, 09:22 PM | #15 |
I think Im planning on going to the badlands but with my atv sometime in march.Im heading to Terre Haute saturday to a big junkyard,maybe I will find one there.
02-28-2007, 11:07 PM | #16 |
72 chevy
I got a 10 bolt in my blazer and i want it to go boom so i can get a 60. But it hangs right in there and thats with 40s on it. I dont *****foot around either. When you all are going to the badlands sometime give me a yeal ill go to sounds fun.
Ed I got a atv to sounds fun also. Give me a yeal when you go iv never been there. Last edited by CrashEd; 02-28-2007 at 11:30 PM. Reason: ATV |
