11-22-2020, 07:46 PM | #1 |
64 super track bar needed ECE
I am preparing to lower a 64 c10. I lowered a 64 a few years ago and learned that it is a year specific trac bar mount on the frame. I called Early Classic Enterprises at the time and they made a bar specific for the year. Anyone know if others may make the bar, or someone may have one? Thanks
11-23-2020, 08:51 AM | #2 |
Moderator
Re: 64 super track bar needed ECE
No Limit (a vendor here), POL and CPP makes them.
11-23-2020, 04:00 PM | #3 |
67-72 parts collector,…
What was the reason to get a “special” track bar made?
Is the frame mount different? I would use the long version that has a Trailing arm mount on the passenger side. And not use the rear axle mount at all.
11-23-2020, 05:16 PM | #4 |
The 63 and 64 panhard bar mount on the axle was a welded on stand similar to the 60-62 frames. The bar was pretty much parallel with the axle and it was longer than the 65-72 panhard bars. The mounting point on the frame for 63-64 has a different angle than the one for 65-72. I ran into that with my 63 that has a 65-70 axle in it
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-23-2020, 06:58 PM | #5 |
Thanks all.
cwcarpenter; thanks for the explanation |
11-23-2020, 07:36 PM | #6 |
Porterbuilt sells mounts for both ends of the track bar at
www.pbfab.com https://pbfab.com/1963-72-fully-adjustable-trac-bar-kit
11-23-2020, 09:00 PM | #7 |
Thanks lolife
11-23-2020, 09:34 PM | #8 |
Thanks lolife
