Old 01-19-2005, 08:28 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Window channel felt replacement?
When replacing the felt channel that goes across the top of the door and down the side, do you have to remove the window or can it be done without doing this?. Also what about the division bar felt?. Does the wing have to come out to replace that one?. Thanks
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-19-2005, 08:36 AM   #2
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I've had my originals in and out a few times by just pulling it out on the top section and sliding it down the track with the windows in place. I can't say if new ones would cooperate though.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-19-2005, 08:47 AM   #3
Dean
Dean's Avatar
You would definitely have to pull out the cozy wing to replace that one. And it is not a fun job being that the felt/rubber is held on by rivets. Pulling the window out was actually the easy part...........
Dean is offline   Reply With Quote
Old 01-19-2005, 09:10 AM   #4
1969K10
1969K10's Avatar
Pull the window, it'll make things much easier, and short in the long run
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 01-19-2005, 09:21 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Thanks for the replys guys. I was hoping I could just work it in by rolling the window up and down a little at a time.
Jim
Old 01-19-2005, 10:23 AM   #6
ksamps01
If you are not replacing the vent window rubber you can do it with the window in. It took a little wiggling but that's how I did mine.
1967 Chevy LWB Fleetside
350/400 (Worn Smooth Out)
Resto in progress
It may be ugly but at least it's slow!!
ksamps01 is offline   Reply With Quote
Old 01-19-2005, 11:50 AM   #7
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
I've replaced mine twice without removing the window , once when I first got the truck and after I had it painted.
Just take it slow if there is any excess cut it at the bottom inside the door panel .
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
