01-24-2021, 10:19 AM | #1 |
Body Exit Exhaust
Hi All, I am thinking of doing a body exit exhaust on my 57 Fleetside C4 project. Would like to exit in front of the rear wheel well. Does anyone have any experience on this? Are there any cons on this may exhaust residue? Thanks Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
01-24-2021, 02:38 PM | #2 |
Re: Body Exit Exhaust
Of course there will be exhaust soot on your paint and depending on how you do it, the hot exhaust will damage the paint.
I'd not do body exit. It's just unnecessary body work, fabrication, the potential for rattling of the piping if it isn't mounted just right AND because of the residue even if behind the rear fenders.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
01-24-2021, 03:11 PM | #3 | |
01-24-2021, 06:30 PM | #4 |
have you been behind a school bus lately? they dont have 6" sewer pipe exhausts, actually the same 2.5" piping they always had, but it exits through the bumper in a large 6" diameter pipe called an "ejector".
the way it works is, the big pipe is open on the back side and the 2.5" pipe only sticks about halfway in. the small pipe exhaust pulls cool air in the backside and ejects the exhaust and extra air out the back at a lower temp than just exhaust. I didnt see any soot on the school bus either but I guess it could be there. if i wanted an exhaust passing through a body panel I would use the same approach. no vibration, cooler temp on the paint, easy to keep clean too.
01-24-2021, 08:18 PM | #5 | |
01-24-2021, 10:21 PM | #6 |
I'm thinking you would get tired of it just after the "oh cool" part wore off. I ran the pipes out from in front of the rear wheels on my 71 GMC for a long time and the exhaust gets the rear wheels pretty cruddy along with getting real tiring on road trips if you have loud pipes. The sound bouncing off the Johnson barriers on short distance runs is fun for a while but the constant drone hour after hour on long trips is real tiring.
Truth be known I have probably driven way more miles with the exhaust exiting in front of the rear tires on my trucks than out the back.
01-25-2021, 08:14 AM | #7 |
I don't think you will have much problem with the exhaust heat on the paint. The header pipes on my Cobra are less than 1/2" from the paint and fiberglass body where they exist behind the front wheels and no issues with the heat affecting the paint. And my header pipe is a lot hotter than your tail pipe.
53 Chevy 3100, SBC 355, 700R4, S10 frame, Ford 8.8 rear with 4.11 gears, front disc & rear drum brakes |
01-25-2021, 09:59 AM | #8 |
I don't think it would be hot enough to burn paint as there is a stainless ring around the opening. I was more concerned with exhaust gas on the body. I was going to exit in front of the rear tire. Again this is a long ways off and worried I won't be able to get a pipe over the C4 rear suspension and not hit the bed. Thanks everyone for the opinions it is much appreciated. Steve
01-25-2021, 12:35 PM | #9 | |
Department of Agriculture study: https://www.fs.fed.us/eng/pubs/pdf/08511816.pdf As far as dirty exhaust goes, keep the engine tuned properly and use a catalytic converter and you'll greatly reduce the chance that carbon will accumulate. |
01-25-2021, 02:37 PM | #10 |
Plenty have the C4 IRS already and have routed exhaust around it. It won't be an issue if done thoughtfully.
01-25-2021, 05:12 PM | #11 |
I laid the cross rails on the frame today and checked the distance I have to work with and you are right there is plenty of room for exhaust. Thank You Steve
01-25-2021, 06:32 PM | #12 |
Nowadays it's fashionable to have exhaust soot on your paint.
1951 Chevy Panel Truck |
01-25-2021, 06:33 PM | #13 |
How cool is this?
01-25-2021, 09:30 PM | #14 |
01-25-2021, 09:36 PM | #15 |
Haha, spend $15,000 on a paint job only to have your truck be worth $5000 less! It's crazy to see guys wrecking what once were very expensive paint jobs to cover them with fake patina.
01-26-2021, 08:38 PM | #16 |
In my day the patina look was the "I haven't got to that yet" look.
01-27-2021, 10:33 AM | #17 |
Thanks for the opinions and pics. I am leaning toward running over the axle and out the sides like a typical dual exhaust. Steve
