07-11-2007, 05:14 PM | #26 |
Next project: 1970 K10
Re: For those waiting on Camaro caliper brackets....
Mixup - I will. I also plan on taking pictures of the install and write up a set of install instructions.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
07-11-2007, 05:18 PM | #27 |
nice job i never gave up. when you have them ready let me know and i will send you the funds
07-11-2007, 05:20 PM | #28 |
Put me in line
1972 Cheyenne 402 LWB 2005 Silverado X-Cab 5.3L 2004 John Deere L120 20HP B&S |
07-11-2007, 05:22 PM | #29 |
computer illiterate
ill take a set as well. will the camaro calipers work on the caprice rotors? or will they have to be used on camaro rotors (diameter/thickness) because the camaro rotors are 5x4.75 bolt pattern arent they?
72 2wd blazer 72 swb 4x4 |
07-11-2007, 05:32 PM | #30 | |
Thanks guys!!!!!!
07-11-2007, 05:33 PM | #31 |
What year camaro rear calibers will the kit take, that has the Ebrake
07-11-2007, 05:35 PM | #32 |
93-97 F-bodies.
07-11-2007, 05:42 PM | #33 |
put me on the list, please....
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
07-11-2007, 06:03 PM | #34 |
Gotcha down pcmcobra!
07-11-2007, 10:45 PM | #35 |
______________
S O L D !
Let me know when they're ready and I can PayPal you again. Thanks for the PM and the update. I know everyone here appreciates your hard work on these. |
07-11-2007, 11:19 PM | #36 |
07-11-2007, 11:31 PM | #37 |
These brackets are built around Impala rotors, you'd need to find six lug rotors with the same depth hat as an Impala rotor and most likely have them turned down to the Impala thickness for them to work.
Hope you don't mind me jumping in Bob.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 07-11-2007 at 11:36 PM. |
07-11-2007, 11:55 PM | #38 | |
07-12-2007, 12:02 AM | #39 |
Trucks N Tranzams
Bob,
Put me on the list for a set. These are really cool.
Don '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
07-12-2007, 12:44 AM | #40 |
Sleep-Deprived
Just a note on axles: I've got some aftermarket 5 lug axles - bought them used - and don't know who made them, but the rotors I have will have to be taken to a machine shop and turned. The center hole is not quite big enough. The rotor has about an 1/16 gap or so between the backside of the rotor and the mating surface of the axle.
This is with the Caprice 5x5 bolt pattern rotors from O'Reilly's. I think the Impala would be the same but there may be differences in rotor manufacturers?
1971 K/10 Long Fleetside 350/350 - 6" Lift 1969 C/10 SWB 292 - Sold It |
07-12-2007, 01:32 AM | #41 |
Great job as always!!!
Just a tip for everyone that will be needing calipers.. Contact Fbody Motorsports, as they usually have them in stock (used), got a set from them when i converted my 3rd gen camaro to 4th gen rear end. cost me around $50 for the pair with brackets.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 07-12-2007 at 01:34 AM. |
07-12-2007, 09:23 AM | #42 |
dsigh - Your on my list bud!
Chris - Don't mind at all, thanks! Arad68 - Gotcha on the list now too. brak - Thanks! And as to what 69_hafton was talking about, I had to do that on my stock axles too. I got my rotors from www.rockauto.com . The arrow in the pic below shows where the clearance issue is:
07-12-2007, 10:41 AM | #43 |
A group P.M. has been sent to all those who have expressed interest in these. I will be posting an ad in the For Sale section shortly. I don't want to turn this one into a for sale post, so if you did not get a PM for me and are interested in a set, please send me a PM requesting pricing and other info on these.
Thanks to you all for your patience!!!!
07-12-2007, 10:53 AM | #44 |
Bob,
I know that you have me down for a set of the brackets (at least I think you do). Thanks! And I know that you have indicated that you are going to put out a parts list and instructions. So, maybe I'm jumping the gun on you (no pun on your handle intended). I'm just trying to get all of the parts (at least the list of them) together in preparation. First off, use the Impala SS/Caprice 9C1 rear brake rotors (2 - one for each side - no, duh). Raybestos Part # 56450 {PG Plus Outside Diameter 11.61" / 5 Bolt Holes / Vented} Rear Second, need the right and left rear Camaro Z28 PBR calipers. You said www.rockauto.com has them - Raybestos Part # RC10459 {PG PLUS} Rear; LOADED RIGHT CALIPER ASSEMBLY- (LEFT; part# RC10460) http://www.rockauto.com/catalog/x,ca...,parttype,1704 (I know the A-1 Cardone's are cheaper, but the Raybestos description had the best pictures. That's why I'm using them as a reference.) The parking brake cables come separately. But, from the pictures, it appears that the parking brake bracket and return spring are missing. I looked on www.rockauto.com and couldn't find those parts. Am I missing something? Thanks!
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. |
07-12-2007, 11:09 AM | #45 | |
07-12-2007, 12:00 PM | #46 |
Thank you dsigh and Truckstr!!!!
07-12-2007, 01:44 PM | #47 |
Bob, I just paid you with Paypal for the brackets. Thanks again, Ken
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
07-12-2007, 02:08 PM | #48 |
Paypal must be running slow Ken, it's not there. But no biggy, we got plenty of time! I'll keep checking it and let you know when it pops up on my account just so we can be sure there are no problems.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 07-12-2007 at 02:08 PM. |
07-12-2007, 03:24 PM | #49 |
Just got this email from Rock Auto....93-97 Camaro rear calipers anyone???
This email is just a reminder that your RockAuto discount code 675302608791 will expire on July 24, 2007. If you or anyone you know is thinking of doing some vehicle repair, now's the time to order the parts!
Alex 1971 Lil' Red 350 SBC 700R4 |
07-12-2007, 04:07 PM | #50 | |
Thanks! Jeff aka TruckSTR
Jeff '67 short Fleet; my ongoing project. '66 long Fleet; my original "baby." Live life or bust trying. Last edited by Truckstr; 07-12-2007 at 04:08 PM. |
