06-17-2015, 09:57 PM | #1 |
To prime or not?
I pulled my 350 to mainly fix oil leaks. I took off the valve covers, intake manifold, exhaust manifold, oil pan, oil pump, harmonic balancer, and timing chain cover. I did not remove the valve train, cam, or crank. Do I need to oil prime the engine?
Thanks! |
06-17-2015, 09:59 PM | #2 |
Re: To prime or not?
Yes, I would.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
06-18-2015, 07:42 AM | #3 |
If you replaced the oil pump it definitely needs priming. If you didn't replace it I am curious why not?
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
06-18-2015, 12:39 PM | #4 |
x2
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
06-18-2015, 01:01 PM | #5 |
Since you have already pulled the distributor (changing the manifold) I would. Just cheap insurance. Could probably have gotten away with turning it over with the coil wire off for a bit, but why would you not want to? Unless you already stabbed the dist.?
"Life is too short to drive a boring vehicle". Later, Wayne |
06-18-2015, 01:20 PM | #6 |
06-18-2015, 02:48 PM | #7 |
Prime is fine. Slicker the quicker.
06-18-2015, 04:00 PM | #8 |
x4
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
06-18-2015, 04:59 PM | #9 |
Old Duffer
Priming is really easy. It doesn't matter if the engine is still on the stand, or in the truck. Take the distributor out, get a piece of round stock or an old large screw driver a couple of inches longer than the distance from the dist. flange to the bottom of the shaft. If you used round stock flatten the end so it looks like a large screw driver. (I had an old wooden handled screw driver that had broken years ago, so I just cut it off and the business end is in my "special tool" drawer for just this purpose.) Anyway, chuck up the screw driver in a variable speed drill, insert this into the engine, engage the pump slot, and turn the oil pump shaft until you see evidence of oil at the rockers. (During the re-assembly, I hope the plastic guide went back on the pump shaft.) the only tricky part is when you get done priming, the slot has to be in the right position to allow the dist. to engage. Don't force anything, when the pump slot is correct, the dist. will "tunk" right in.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
06-18-2015, 05:16 PM | #10 |
It's worth $10 or whatever the proper tool costs. Failing that we all have old distributors around, just make one out of it. Grind off the gear or (at least one aftermarket ones I've seen) drive out the roll pin and remove the gear.
06-18-2015, 05:41 PM | #11 |
Modifying an old distributor is a good option. Simply turning the pump shaft with a screwdriver or similar is not sufficient. Without something to direct oil to the passenger side galley it will just dump back down the distributor hole & the valve train on that side will be starved. Here is a pic of the proper tool which mimics the distributor:
06-18-2015, 06:12 PM | #12 |
Old Duffer
Now we're getting there! Everybody says "Prime, prime, prime" but then let an old geezer jump in and say HOW to prime, and out comes the state-of-the-art stuff!
Not trying to offend 68_step, he probably already knew this, but for the new crew I thought it might be worth a few words to explain the process.
06-18-2015, 06:35 PM | #13 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
06-18-2015, 10:20 PM | #14 |
06-18-2015, 10:23 PM | #15 | |
06-18-2015, 10:27 PM | #16 | |
06-19-2015, 12:16 AM | #17 |
06-19-2015, 01:07 AM | #18 |
That's what I was thinking. And yeah, I'd have replaced that pump.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
06-19-2015, 03:56 PM | #19 |
06-19-2015, 03:58 PM | #20 |
06-20-2015, 09:55 AM | #21 |
I ground the teeth off of an old distributer and it works great. I had it laying around and needed it right away. The tool would be great and probably takes less room in the tool box. Both work great.
