07-15-2018, 11:47 PM | #1 |
heater hose question
I have a 71 c10. it has a 2005 5.3 out of a Silverado.right now I have no a/c or heater.the installer blocked off the heater hose outlets. should they be blocked off or looped together?if looped together is the answer what size hose do I need?THANKS
07-16-2018, 12:01 AM | #2 |
Re: heater hose question
Better to run a bypass hose. I’m running one on my LS swap.
https://www.amazon.com/Heater-Bypass.../dp/B013QNJ9SQ |
07-16-2018, 12:36 AM | #3 |
THANKS I was not comfortable with capping them off.
07-16-2018, 01:06 AM | #4 |
X2....I was told not to block them off if not running a heater...and to use a loop....
07-16-2018, 11:20 AM | #5 |
Yes, they must be looped because the LS water pump, unlike the old small block chevy, does not have an internal bypass.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
07-16-2018, 09:56 PM | #6 |
THANKS everyone bypass hose is ordered. I ordered a extra for the guy who did the swap for me to show him the best way. this is only temporary till I can get the vintage air ordered.
07-17-2018, 12:01 AM | #7 |
At which time you will go right back to blocking them off...... The way I understand it, which may or may not be right, is the system was designed the way it is for faster warm ups to help with emissions. Once the cooling system is full, it shouldn't matter. When you put a Vintage Air set up on it, whenever the A/C is on, the heater hoses will be blocked off by the heater control valve, essentially blocking the same ports off. I've personally put well over 200k miles on LS swapped vehicles with this same set up and never had an issue, most of which miles were put on in the heat of the summer with the aircon on.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-17-2018, 05:11 AM | #8 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
07-17-2018, 06:22 AM | #9 |
Yes there is, those discussions get pretty heated at times. LOL! I've done it both ways and haven't seen a difference in either one.
07-17-2018, 10:27 AM | #10 |
So if you are blocking them off what is the correct method? Is there a part that fits over the tube and then tightens like a hose clamp?
07-17-2018, 06:48 PM | #11 |
mine has some rubber caps held on with hose clamps
07-18-2018, 12:42 AM | #12 |
BMW & ASE Master Certified
In can say with experience, you may overheat if you have a smaller radiator and the heater core lines are blocked. In my bmw 5 series LS swap, the heater core lines go to the factory heater valve. Maybe the same as vintage air system, ac on, no need for hot water to flow inside the ac box, and its closed. Ive seen the coolant temp rise above 220-230 before I realized what's going on (automerer gauge) That's at the water drilled and tapped next outlet by the tensioner. The temp sender in the head goes higher. As soon as the heater valve is opened, coolant temp goes down and back to normal. Before I thought the radiator was too small, stock. It wasn't the road, it was the design of the heater core flow. Also have the 160* stat
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
07-18-2018, 01:50 AM | #13 | |
07-18-2018, 09:09 PM | #14 | |
Thanks for the help
07-19-2018, 05:12 PM | #15 |
The LS runs better when it’s at or around 195, this allows the intake to better atomized the fuel so it’s runs more efficiently and economically.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
