Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-05-2021, 12:33 PM   #1
SwitchbladeII
Fuse Box
Does anyone have a list of what blades in the fuse box are hot all the time and which ones are hot with key on? Also which are fused? Could fiqure this out if I had power going to the fuses at this time. As always any help is appriciated.
SwitchbladeII is offline   Reply With Quote
Old 02-05-2021, 02:54 PM   #2
RustyPile
RustyPile's Avatar
Re: Fuse Box
The first tool you'll need when doing electrical work is a wiring diagram. It will answer most of your questions. If you don't have one, go here and download the proper one for your vehicle..
http://67-72chevytrucks.com/vboard/s...d.php?t=185856
RustyPile is offline   Reply With Quote
Old 02-05-2021, 02:59 PM   #3
SwitchbladeII
Re: Fuse Box
Thank you for the link. I have a wiring diagram and do refer to it often. In this case a connected electrical system and a test light would me a better solution IMO. I will check it out when my wiring is complete just hoping to find an answer to my questions before I reach that point.
Old 02-05-2021, 08:53 PM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Fuse Box
If we knew what year truck you had would be very helpful seeing how there are many, many types of GM, GMC trucks out there.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 02-05-2021, 10:00 PM   #5
SwitchbladeII
Re: Fuse Box
Thanks Andy for pointing that out. I should of included it along with my question. It's a 69 C10.
Old 02-05-2021, 11:05 PM   #6
RustyPile
RustyPile's Avatar
Re: Fuse Box
In most cases, you don't need to apply power to a circuit to test it.. Simply use the continuity feature on a DVM...
Old 02-06-2021, 11:30 AM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Fuse Box
This is what you should have.
Old 02-10-2021, 02:31 PM   #8
SwitchbladeII
Re: Fuse Box
Thanks Andy! This is what I was looking for! Just saw this, I must of missed the email that I had a response. Thanks again!
