Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 03-04-2021, 12:10 AM   #1
freds40
Only one brake light out
Just completely rewired my truck. Everything on the truck works except for the driver brake light. Thought this would be an easy one, but the bulb is good and what has me hung up is that the turn signal works. I checked the wiring along the frame, and there is no power as far forward as the connection at the firewall. Not sure where the loss of power is.
freds40 is offline   Reply With Quote
Old 03-04-2021, 05:29 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Only one brake light out
The white wire in the column plug is the brake power wire. the yellow wire is for the brake/turn signal on the left side . If the left turn signal works then the wiring is good on the yellow wire to the rear. The brake and turn signal use the same wire, yellow on the left and dark green on the right.
If both the brake and the turn signal work on the right then the dark green wiring is good and the problem is most likely in the turn signal switch for the left stop light contact.
IF you make a short jumper in the column connector between the white wire and the yellow wire then step on the brake pedal and the brake light comes on, then it confirms that the problem is in the turn signal switch.
It is not uncommon that the contacts inside the turn signal switch become dirty or corroded and fail to pass current through to the wires. Spraying some contact cleaner inside the switch on the contacts and maybe some WD-40 might be all that's needed.
Another check you can make is to swap the yellow and green wires in the column connector and see if the problem flips to the right side.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
