10-14-2019, 11:23 AM | #1 |
EFI fuel line routing
I ordered a kit from TanksInc, and I think I may have the wrong filter/regulator.
I have an SUV 5.3 with the truck intake. I guess this type of stock setup uses this type of flow system? Would you agree? But I ordered this type of Filter/Regulator: It seems that the above Regulator does not need a return line running from the engine. The return line out of this filter goes right back to the tank? So, do I need to just run my return line from the engine, and "Y" into the return line from this regulator to the tank? Or do I need to get a completely different filter/regulator? |
10-14-2019, 11:56 AM | #2 |
Re: EFI fuel line routing
I have run both styles. The first style is factory on 2000-2004 truck intakes which have a vacuum pressure regulator built in to the fuel rail system, pressure line to fuel rail/ return line to tank.
Second style uses the Corvette style regulator shown, pressure line to regulator/return line from regulator to tank, no return line on fuel rail system. Both style work well but you can not mix and match.
My '47 C.O.E build |
10-14-2019, 02:01 PM | #3 |
My 6.0 engine is the return rail style...I used -an fittings and blocked off the rail return ,and used the vett filter/reg right after the pump....either way works...but like fasttoys said ,dont mix and match
10-22-2019, 02:45 PM | #4 |
Do you have a return line on your truck ?
I have tanksinc setup with that filter/regulator and used hotrodfuel 6AN fuel hose braid ........ But yeah - I have a 2007 truck intake (hummer) with no fuel rail return.
FAKKY 57 PANEL BUILD |
