Old 01-18-2021, 09:05 PM   #1
weider1717
87 owners help needed on a bolt, thanks
Folks,
I recently pulled my 87 350 tbi. The oil pan had a bolt on the right side that also held a bracket to support some cooler lines.
I set this bolt aside and I have misplaced it. I took a picture of the surrounding bolts and the head mark looks marked “LF” see picture.
Could an 87 owner look at the bolt which holds that bracket to see if it is also marked “LF” so I will know that is specifically correct as I am looking online for a correct bolt to replace it. Also any idea where to get it so far no such luck online if the “LF” is correct. I’m on the picky side and would like to put back what came on it headmark etc..
Thanks so much 🇺🇸
weider1717 is offline   Reply With Quote
Old 01-18-2021, 09:08 PM   #2
weider1717
Originally Posted by weider1717 View Post
Folks,
Thanks so much 🇺🇸
Old 01-18-2021, 10:17 PM   #3
Just call me Sean
Just call me Sean's Avatar
Re: 87 owners help needed on a bolt, thanks
The bolt has a stud head. The bolt goes on first then a nut holds the bracket to the bolt.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-19-2021, 11:58 PM   #4
slb1985
slb1985's Avatar
If it helps the "LF" is a stamping for Lang Fasteners who manufactured the bolt. The 3 lines on the face mean it is a grade 5 bolt, and the head style is a "Hex Washer" style bolt.
1987 R10 Silverado - Rusty But trusty Daily
1984 C10 Custom Deluxe - Newest Project
slb1985 is offline   Reply With Quote
Old 01-21-2021, 02:26 AM   #5
Pontiac1976
Pontiac1976's Avatar
well oil pan bolt scrapyard. Depending on side pan it's the trans cooler lines bracket(right), or motor oil cooler bracket(left)
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 01-21-2021, 05:36 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The bolt that holds the cooler line bracket has a stud on it's head like Sean said. Install it then the bracket with nut is secured to it.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-27-2021, 07:44 PM   #7
legendman
legendman's Avatar
Hey TX Firefighter good to see you back, working on anything?
Always impressed by your threads.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 01-27-2021, 08:44 PM   #8
Tx Firefighter
Thank you sir.
I'm goofing with an OBS truck right now. I'm getting old and don't really do into full builds much anymore except motorcycles. Just fun fix up projects that I can drive and enjoy as I work on them. It's getting so expensive nowadays and the parts are such crap quality it has dampened the fun on it all a bit to be honest.
Old 01-30-2021, 11:17 AM   #9
83GMCK2500
Thank you sir.
Ha-HAA, you know a couple times a year I go back and read your build threads for ideas/motivation, absolutely loved your attention to detail. I am also in the "Great to have you back!" group.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-30-2021, 11:34 AM   #10
legendman
legendman's Avatar
I do the same, great threads. They inspire me to do work on my collection.
