Old 01-07-2021, 04:26 PM   #1
Luvlegs
Luvlegs's Avatar
Hey all, quick question (while I'm sitting in these)...
Anyone ID these - before I put any effort into saving them (theres 2). Currently, the drive is out the "front" of them....
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-07-2021, 05:04 PM   #2
b454rat
Re: Hey all, quick question (while I'm sitting in these)...
Small block chevy, could be 305 or 350. Not too many other options I don't think....
Old 01-07-2021, 05:27 PM   #3
geezer#99
geezer#99's Avatar
More likely a 283 or 327.
Casting number will provide more info.
Old 01-07-2021, 05:42 PM   #4
AussieinNC
Moderator
AussieinNC's Avatar
327 OMC (SBC) from look of intake with "front of engine" fill tube and no PVC on the rocker covers....
Check casting number on flywheel end of engine and post the number...it will tell us immediately what it is...
BTW...most OMC 327 are 4 bolt mains,,,,,
Check them really well for valley cracks...these get left out in inter weather with zero freeze protection...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-07-2021, 06:18 PM   #5
Luvlegs
Luvlegs's Avatar
For the life of me I can seem to find any numbers on the back side of the blocks. Or the heads for that matter. I do know early/mid 70s. I'll dig some more tomorrow. Thanks all!
1972 C10 L6 3OTT
Old 01-07-2021, 10:28 PM   #6
bhap
bhap's Avatar
If they are in the same boat, one is probably reverse rotation. My early 60's Chris Craft 283 is very similar.
bhap is offline   Reply With Quote
Old 01-07-2021, 11:08 PM   #7
Luvlegs
Luvlegs's Avatar
And I think they are, the one distributor has stickers on it " re-numbering" the terminals.
1972 C10 L6 3OTT
Old 01-08-2021, 01:52 PM   #8
Dead Parrot
Unless you know the history, almost anything could be hiding in there. How many 350 blocks will come back as 160HP stock based on numbers that after opening up are really 300+ HP 383s? And you can't really tell by the 'dress' as it will fit on blocks from 283 to 400.
Boat owners are just as likely to want a faster hole shot as a car owners want a quicker 0-60.
If one is reverse rotation, it might be worth saving just for that reason.
Dead Parrot is offline   Reply With Quote
Old 01-08-2021, 02:18 PM   #9
Ziegelsteinfaust
If they are truly boat motors.
They usually have better blocks in terms of casting materials.
Plus either high nodular cranks or very often forged.
I like buying old boat motors for performance applications as they used to effectively equal race blocks, but on a budget I could afford. Similar to how brand F guys use FT parts to build a wicked FE.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-09-2021, 04:47 AM   #10
gmc684x4
Here is a video to show you where to look for casting numbers
https://m.youtube.com/watch?v=H0mG4uU9xFk
gmc684x4 is offline   Reply With Quote
Old 01-11-2021, 01:42 PM   #11
Luvlegs
Luvlegs's Avatar
Got one...3914678 68-79, 302/327/350 - car/truck 2 bolt. Sooooo.... Let em go?
1972 C10 L6 3OTT
Old 01-11-2021, 04:12 PM   #12
Tom
driving is in my blood
Tom's Avatar
As apposed to what exactly? Sounds like a normal 4" bore block, the kind everyone wants when doing Gen I engines.
Old 01-11-2021, 04:41 PM   #13
Luvlegs
Luvlegs's Avatar
They're in a boat that is being (I'm) demolishing. Washed up sideways on shore and will most likely have to reach out to them with a backhoe. It's a large boat, holes in hull. It'll be a bit of an effort (and it's cold - ha). I guess I'm wondering if worth the effort or wasting my time.
1972 C10 L6 3OTT
Old 01-16-2021, 11:56 PM   #14
SunSoaked
SunSoaked's Avatar
What exactly are you "sitting in?"
SunSoaked is offline   Reply With Quote
Old 01-18-2021, 10:12 PM   #15
mattfranklin
mattfranklin's Avatar
If those things have a jet-drive or vee-drive, they could also be worth some money -- as long as you're salvaging things. Check eBay for typical prices to see if your time is worth it.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 01-27-2021, 07:21 PM   #16
Myself
I would save 'em first, then figure out what they're worth. Good cranks and rods for sure....those manifolds are probably worth $100 a piece...etc.
Myself is offline   Reply With Quote
