12-02-2020, 05:00 PM | #51 | |
Re: Dakota Digital HDX with the OBDII BIM module
Yeah, I was mistaken. 99-02 trucks I dont believe have provisions for oil pressure in the PCM but it can be added and enabled in the red/blue PCM's, but 03+ with the green/blue PCM's do. I am using an 06 PCM with a PSI harness in my swap, but I believe my engine has a pressure switch rather than sensor. I'm using a tablet + OBD2 reader for a dash, but the PID for Oil Pressure (22115c) with what I believe to be the right equation is only showing "0" or "1." Your comment actually made me dig further into adding oil pressure to my tablet display, so thank you for following up! |
12-02-2020, 07:02 PM | #52 | |
The splitter I bought doesn't work simultaneously, but I used it anyway, It still works better for me the way I mounted it all I have to do unplug the DD unit. What is your goal with the splitter?
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
12-03-2020, 07:36 PM | #53 | |
I have the OBDII BIM and an OBDII Cruise module so I have to use a splitter on at least those. I would like to be able to plug in a tuner or scan tool without removing the cable? I bought an AMP research true pass through splitter. I will do the BIM module for the gauges first. Once that is working I will add the cruise module and see if we can get that to work. If I can get both to work I mat add a second AMP research splitter and see if I can scan while everything is all plugged in?
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
12-03-2020, 09:31 PM | #54 |
I'm curious why do you need the cruise control bim? The PCM and TAC in my 2003 unit is just 4 wires to connect to stick on column and power/brake switch. Does your newer PCM/TAC setup not have that?
12-03-2020, 09:41 PM | #55 |
If I remember correctly all the handle switches are opposite what the PCM needs normally open instead of closed or the other way around needing relays. I would have to change the brake switch (cheap and easy and I have one). I am paying labor due to injuries so If I can just plug in the handle and an OBDII cable and just 2 wires to the existing brake switch it will be easier in my situation. I will revisit this and post if it works or is problematic.
12-06-2022, 11:16 PM | #56 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-06-2022, 11:44 PM | #57 |
Still getting ready for paint so not enough run time to give an update. The gauges work with the splitter in place. I have the cruise control stalk on a not yet installed tilt column. Will not be able to test the cruise control in the splitter until final assembly.
04-05-2023, 11:37 AM | #58 | |
