11-02-2002, 08:30 AM | #1 |
Ain't we cute?
Need help bolting motor to tranny!
Well, I got my new motor in but can't get the damn thing to snug up to the tranny bellhousing. It's a regular ole 350 and TH350. I think I put the motor mounts back in just like they were but there's about 1/4 to 1/2 an inch in b/t. If I try and tighten the bolts, I can no longer turn the flywheel. The flywheel bolted to the TC just fine. Anyone got pics of their SBC motor mounts (old style)? I only hand tightened my mounts until everything's adjusted. This and my PS bracket are all I really lack. Help?
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES! FOR SALE $3900 |
11-02-2002, 08:39 AM | #2 |
I have better luck putting the TC in the bell housing first, then snug up the bolts on the bell housing. Once that is done I bolt the TC to the flywheel.
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
11-02-2002, 08:50 AM | #3 |
computer illiterate
is your flywheel on backwards?
72 2wd blazer 72 swb 4x4 |
11-02-2002, 08:52 AM | #4 |
Fabricate till you "puke"
I agree with 72chevycheyenne, chances are that the converter is not seated in the pump. You need to separte the eng & trans to scope the trouble. You should be able to "feel" the converter drop in at 3 places when installing it on the trans. You have to turn the verter while installing , to insure that it is all the way in........failure to do this will cause damage to the pump, converter & trans. good luck.....longhorn
11-02-2002, 11:47 AM | #5 |
Ain't we cute?
I never pulled the TC from the trans. That's why I am confused. I guess the TC was probably unseated when I pulled the motor, huh? Thanks, guys.
11-02-2002, 02:17 PM | #6 |
Yeah dont crank them down to tight and ruin your trans.sounds like convertor isnt seated to me also.
11-02-2002, 06:20 PM | #7 |
Ain't we cute?
Thanks, fellas. The TC wasn't fully seated but it is now! I needed to pull it anyway as my PS bracket had to be bolted to my motor mount and it wouldn't line up with it in.
Thanks again! Jason
11-03-2002, 12:34 AM | #8 |
its all about the +6 inches
Hope you didn't FUBAR the tranny pump. Since you didn't start the engine or bear down on the bellhousing bolts, your probably OK.
11-03-2002, 01:18 AM | #9 |
Ain't we cute?
I hope so too, Andy.
