11-02-2002, 10:53 PM | #1 |
i love summertime
quick question
i jacked up the rear end of the frame and was curious if it has posi, when i spun one wheel the other one didnt spin at all, does this mean its posi or limited slip? when the other one spins the opposite way i think it means its open, so i dont think its that ? but could someone tell me if its posi or limited slip
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
11-02-2002, 11:00 PM | #2 |
either open or broken posi..if it was a posi both tires would spin the same way
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
11-02-2002, 11:01 PM | #3 |
I'm thinkin' that doesn't sound right....at least from what I thought I knew....
1969 Blazer: 350/350, 4X4, HEI, Edlebrock carb/intake, dual flowmasters, np205, 3:07's and the rest is mostly stock. The front end disc swap is finally complete 2002 Z71 Tahoe. CAI, Flowmaster 40, Silverstars in high, low and fogs and a bunch of mods (upgrades) inside and out. |
11-02-2002, 11:12 PM | #4 |
Did you have the transmission in neutral? On an open differential setup, when you spin one wheel and the trans is in neutral, either the drive shaft Or the other wheel will spin in the opposite direction. Depends on which has less resistance to turn.
If the trans was in gear or park and only one wheel spins.... better find a part store thats close lol, because your going to be walking there , Truck wont move with broken spider gears OR bad posi plates/springs that allow the diff to freewheel. Last edited by Piston; 11-02-2002 at 11:14 PM. |
11-03-2002, 02:36 AM | #5 |
i love summertime
there is no driveshaft in the frame, its just rolling, no body or cab/tranny. i dont think anything is broken as far as i know, i must be open?
11-03-2002, 02:56 AM | #6 |
You'll need to have someone hold the pinion while you turn a wheel. If it were a posi, both wheels would have been turning regardless of a driveshaft in place or not.
11-03-2002, 03:10 AM | #7 |
My other Love
sounds like an open diff to me. Pull the cover off anyways. Its a good idea to look it over and change the rear end fluid which will smell like camel piss if it has never been changed before
MEMBER DISCS UP FRONT CLUB
Hooter_5@hotmail.com AC/DC RULES!!! First generation Monte Carlo club pictures of my life |
