01-15-2017, 11:01 AM | #1 |
Hard fuel line source?
When I move my fuel tank to the rear, I want to use hard line from the tank to the fuel pump. The only rubber will be a short section from the tank to the frame, and the frame to the fuel pump.
Any suggestions as to where to get the hard line? I can bend it and flare it myself, I just need a source. |
01-15-2017, 11:10 AM | #2 | ||
"I ain't nobody, dork."
Re: Hard fuel line source?
Most parts houses have steel hard line on the shelf. I know the one I go to has sticks and coils of line in 3/16", 1/4", 5/16", 3/8", etc.
If you want stainless, places like Inline Tube or Summit Racing sell it in coils or sticks depending on how much you want. Gary
01-15-2017, 11:15 AM | #3 |
Thanks Gary. Regular steel line is what I was planning.
01-15-2017, 11:24 AM | #4 |
I just ran all new fuel lines to a 6.2 diesel with a 3/8" supply and 1/4" return (similar for vapor returns on 71-72's) to an in cab tank as well as a tank after the rear axle.
I used a common transfer switch from the 80's and 90's mounted to the frame with a simple double pull double throw switch (no central off) to determine direction since it stops pulling power after it's internally switched. ACDelco U7000 https://www.amazon.com/ACDelco-U7000.../dp/B0013FY5KW. I was recommended to use NiCopp for fuel as well as brake lines. It's much easier to flare than steel and you can bend it mostly by hand. Additionally, it shouldn't rust like steel and fail. http://agscompany.com/product-catego...-lines/nicopp/ The only thing to be aware of is that Copper products tend to crack when flexed slightly but repeatedly over time. To alleviate this i installed the lines with rubber coated metal hangers. This would be bad for steel since it would trap moisture.
71 Chevy C10 350/TH350 71 GMC C20 350 (donor truck) 82 Chevy K20 Suburban 6.2/TH400/NP 95 Chevy 4x4 1500 Tahoe 6.5T/4L80E 04 Chevy 4x4 3500 Silverado 6.6T Duramax/Allison 1000 (work truck) 09 Chevy Aveo 1.6L/5 speed manual |
01-15-2017, 11:31 AM | #5 | ||
I have an older mom and pop type store that's been around this town for eons. They used to be a "Parts Plus" distributor, but now they are an "Auto Plus" parts distributor. They have a lot of parts in stock that the other chain stores in town don't usually have on the shelf, so I feel pretty lucky they are here. I've watched the store go from the original owners, to their son, and now to their grand daughter. Funny thing as their old store is nestled right between an O'Reily's, Auto Zone, and a Les Schwab tire center. They still maintain a rack of catalogs that are up to date since their antiquated computer system is pretty limited. It just feels right to walk in there.
I can get anything I need pretty much with in the next day if they don't have it on the shelf already. They have a lot of brake and fuel line options along with all the fittings to go with it. Gary
01-15-2017, 11:55 AM | #6 |
You might look into using a Suburban line. I believe they use the same piece from the pump back to under the cab as a pickup. Then there is a short piece of hose to the hard line which contiunues back to the tank behind the rear axle. You might try searching the Suburban section for photos.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-16-2017, 10:06 AM | #7 | |
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
01-17-2017, 05:58 PM | #8 |
the nicopp also has iron in it ...nice stuff...advance has it by me
1970 short step c10 leaf spring 454 |
01-18-2017, 01:43 AM | #9 |
does anyone use aluminum fuel line? it is easy to manipulate and looks good.
