Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 02-08-2019, 01:34 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
WTB - Rear Spring Hangers
Wanting to buy rear leaf spring hangers - converting to 63'' rear springs and need a clean set of hangers
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 02-08-2019, 11:34 PM   #2
KrazyRay
KrazyRay's Avatar
Re: WTB - Rear Spring Hangers
I have several to choose from. What style/profile hangers are you looking for? All 4 or just the rear of the rear?
KrazyRay is offline   Reply With Quote
Old 02-09-2019, 08:05 AM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
You might wanna ask specifically for K10-k20, C30, or k30
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 02-09-2019, 12:23 PM   #4
6600DURAMAX
Really not sure on all the differences. It seems like the 73-87 spring hangers hang lower off the frame allowing slightly more lift. Currently I have a set of 63'' springs with 5'' of lift. I am going to want an additional 5+ '' so my thought was using the brackets that hang lower? Not sure all this is making sense. The current set on my frame would work just figured a newer model set might gain me some additional lift.
Old 02-09-2019, 12:24 PM   #5
6600DURAMAX
I would want a full set if I was to change them out
Old 02-09-2019, 02:01 PM   #6
71blksuper4x4
SWB 4x4 Collector
Differences in the length the hangers hang away from the frame to line up the springs. C30 are shorter than k30 but hang off the frame narrower than that of the k10 and k20. I put squarebody k20 hangers on mine, which made it level, but I just have a 3/4 ton rear out of a square body that lines up for mock up. I may change out to K30 hangers yet. 67-72 Hangers hang the same distance away from the frame as c30-k30’s. All of this was trial and error. Honestly, I think you could make the factory Duramax hanger work fine in your application.
TREVOR
Old 02-09-2019, 02:04 PM   #7
71blksuper4x4
SWB 4x4 Collector
Here was a pic from my diesel donor of the stock hangers.
TREVOR
Old 02-09-2019, 02:52 PM   #8
sweetk30
sweetk30's Avatar
measure the center to center of the leaf pad mounting on your axle now .
42.5 = k5-c/k10-ck20
40.5 = c/k 30
other wise you will be moving and welding perches on the current axle .
what year frame now are you using ? whats the axle from ? this has the most importance over the springs as they will fit any of these hangers . its the spacing of the hanger that makes the choice .
as said c-lower hangers and k- taller by 3" on the hangers . for the front hanger of the rear springs only .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 02-09-2019, 02:59 PM   #9
sweetk30
sweetk30's Avatar
i forgot you can do a home brew flip kit with a extra set of front hangers like i did here . these were 2wd short hangers and 6" long shackles for 2.5-3" lift height in the rear of my last build .
found the height i wanted then cut off extra and welded a chunk of angle on the bottom to catch the bottom lip of the frame and 4 bolts per side and 2 in the bottom just like oem rear hanger .
Old 02-10-2019, 04:55 PM   #10
6600DURAMAX
SweetK30 - Any issues with "sway" in the rear end with reverse shackles? Any load carry capacity reduction? Does it require a Track Bar ?
Old 02-10-2019, 05:00 PM   #11
6600DURAMAX
Frame is a C-30 with 40.5'' perch spacing
So I think what you are saying is I would need K30 brackets - they would be longer than the c-30 ones that I have correct??
Old 02-10-2019, 06:49 PM   #12
sweetk30
sweetk30's Avatar
yes 1 ton brackets .
yes 3" taller for the front hanger / bracket only . the rear stays the same .
no real difference i have noticed . i use to run a 4" offroad design flip kit on my old truck and when i scrapped it and built this one to replace it i went less lift for more of a work truck .
i have the 4" flip kit brackets i would sell . there a bit rusty from upstate new york salt belt life . but still super solid and i would use them again if i had to . i will also check i might have a set of k30 front hangers .
Old 02-15-2019, 10:52 PM   #13
6600DURAMAX
Any K30 hangers out there???
SweetK30 - any update
thanks
Old 02-15-2019, 11:03 PM   #14
sweetk30
sweetk30's Avatar
dude sorry . crazy busy week . just got done with my first d-max water pump job .
i hit you up this weekend for sure .
got your pm . but i got a stupid phone ( flip ) i dont text a lot with pics . drop me a pm with your email .
Old 02-16-2019, 09:23 AM   #15
GonicGM
GonicGM's Avatar
I have OEM 1 ton 4x4 rear spring front hangers from 87 V3500 dually dump, fronts only. KrazyRay may have full set or rears. Your frame rails measure 34" outside?
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher
85 K30 SRW 350 TH400 NP205 4.10
87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher
83 K2500 350 TH700R4 8600GVW Dual Tank 4.10
1973 Cheyenne Super 30 DRW Std Cab Z83 4.10
1976 Silverado C30 Std Cab 4.10 DRW (4 sale)
GonicGM is offline   Reply With Quote
Old 02-16-2019, 11:36 AM   #16
6600DURAMAX
GonicGM - yes the frame is 34'' out to out and the spring hangers are 3'' to the center past edge of frame. Any pics of the 87 front hangers?
Old 02-16-2019, 04:42 PM   #17
KrazyRay
KrazyRay's Avatar
I have a full set of OEM 1 ton hangers pulled from a 79 K30 $200 plus shipping.
Old 02-17-2019, 04:16 AM   #18
Madkidd007
Madkidd007's Avatar
Not to try and jack your thread but if you don’t get these fronts I’d be interested. Making my own thread but while searching I came across yours go figure we are doing something so similar.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 02-17-2019, 11:29 AM   #19
1968vetL-71
Junior Member
1968vetL-71's Avatar
I have a set of rear/rear hangers off my 89 V3500. I will post a pic with measurements tomorrow.
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 02-18-2019, 06:42 AM   #20
Madkidd007
Madkidd007's Avatar
Wanted to let you in on where I am with my search. I found some and will be picking them up this weekend. From what I’ve gathered even the 1/2 and 3/4 can have the narrower 40.5 spring spacing like the 1 tons being the 67-72 4wds has the straight rails in the rear. Unconfirmed but will be able to by Sunday.
Old 02-18-2019, 08:03 AM   #21
71blksuper4x4
SWB 4x4 Collector
That is incorrect for 73-87, but all 67-72 4x4’s used the same hangers at 40.5.
TREVOR
Old 02-18-2019, 10:51 AM   #22
6600DURAMAX
Think Ill just use the ones I had. Getting a one ton set would allow me to drop the front of the spring lower getting me a little more lift but then it would kick the pinion down. Ill just use these and add a block. The springs themselves probably got me 6'' of lift - another 4-6'' block should get me level Any one have some longer ubolts.....
Old 02-18-2019, 10:51 AM   #23
6600DURAMAX
Does that r3ear shackle angle look good considering no weight??
Old 02-18-2019, 04:17 PM   #24
Madkidd007
Madkidd007's Avatar
Here is mine with just the weight of the bare chassis. I think you’ll be pretty spotnon especially with the longer springs as they flatten out. And just in case you are still wanting to go lower on the front, you could always do a shackle flip in the rear, only downside is a softer progressive rate so it wouldn’t be so good for towing but I’ll have a set of bags also so for me it’ll be just right.
