Old 01-21-2018, 11:32 PM   #1
WB72
Before and After
WB72's Avatar
Installing components in a naked cab.
It has been a while since I removed everything from my cab before repairing the rust. Months and months later, I am ready to put it all back in.
I have everything bagged and labeled, so this shouldn’t be a problem, but is there a smart order to install them back in? I don’t want to fight with other components during the rebuild.
This is not an A/C cab.
3ott.
Any tips will be appreciated.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-21-2018, 11:53 PM   #2
randy500
Re: Installing components in a naked cab.
Good question...
1. Firewall insulation
2. Kick panel vents
3. Emergency brake unless it’s under the column like a 67-8
4. Brake pedal assembly
5. Brake booster or master cylinder rod.
6. Wiper motor
7. Wiring harness with all dash switches
8. Gas pedal, Oil line and th400 wiring if required
9.dash pad
10. Radio
11. Heater sssembly, pre assembled with controls and cables.
12. Rear window
13. Carpet seat belts and seat
Any order on the remainder but glove box and liner last after heater is tested.
randy500 is offline   Reply With Quote
Old 01-22-2018, 01:06 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Install the gauge cluster before you install the column, or at least before you tighten the column up.
LockDoc
Leon
Old 01-22-2018, 05:19 AM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
Great timing. This exact question has been rolling around in my head this weekend.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 01-22-2018, 09:14 PM   #5
WB72
Before and After
WB72's Avatar
Originally Posted by randy500 View Post
Good question...
2. Kick panel vents
6. Wiper motor
9.dash pad
10. Radio
12. Rear window
Exactly what i was looking for, thanks Randy.
66,000 miles.
Alberta, CANADA
Old 01-22-2018, 10:49 PM   #6
sprint_9
sprint_9's Avatar
I agree, Ill reference this as well once mine goes on in a few weeks. Thanks.
sprint_9 is offline   Reply With Quote
Old 01-22-2018, 11:31 PM   #7
davischevy
davischevy's Avatar
#1. Dash pad.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
