12-21-2015, 03:26 PM | #51 |
Re: Anyone: Delco Pleasur-lift air shocks w POWER PAC compressor?
Wow, I really need one of these setups complete. I have the "shraeder fill" manual kind. Right now I have too much rake anyway, so haven't installed it yet.
BTW, on the topic of concealed carry and newly acquired firearms, I should throw this out there. I have three of them (non-fingerprint kind). Since a gun should be in a holster or a safe and never elsewhere, this makes it trivial: http://www.gunvault.com/
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
12-22-2015, 01:10 AM | #52 |
Carpe manana
I have a complete NOS Pleasur-lift set up (not what's pictured above, another w hoses, mount hardware, etc. complete) - my brother shows no interest in using it on his 66 GTO sadly. If interested, shoot me a PM.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 12-22-2015 at 01:16 AM. Reason: more detail added |
05-01-2020, 03:02 PM | #53 |
Sorry to revive a almost 5 year old thread, but I just got ahold of a gauge like you have pictured here, and want to set it up like Andy did.
My question. What line went where in the back of the gauge, and is the plug that is there suppose to be there? Just unsure how the gauge works
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
05-01-2020, 10:07 PM | #54 | |
Old member
I have this in the Ramp truck now hooked up to my air tank for pumping up tires and such. The fittings are the orignal's for it. I have a couple of extra's just in case one fails.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
05-01-2020, 10:12 PM | #55 |
Old member
Here is how it looks now. I plugged the one inlet off since all this is a gauge for the air tank. I'm not using the vacuum pump.
05-02-2020, 12:18 AM | #56 | |
I plan to just use it as a gauge and do a momentary contact switch to an electric pump to air up my air helper springs just like you did earlier in the thread. Where did you get a fitting to go into the back of the gauge? I also am curious even though it is not relavent to me setting it up properly. How is the knob suppose to work? Is it suppose to allow more pressure the more you turn it??
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab Last edited by kehstr; 05-02-2020 at 12:23 AM. |
05-02-2020, 07:22 AM | #57 | |
Old member
07-10-2020, 04:42 PM | #58 |
I appreciate your help Andy!
One final question. Do you remember the part number for the fitting that holds the line in the back of the gauge? Or at least where you got it
07-10-2020, 10:12 PM | #59 |
Old member
Those fittings where what my dad had left over when he gave it to me. I got a few more from a member on here but ended up using all of them. I have no part numbers and not home to look.
07-10-2020, 11:34 PM | #60 |
Okay I understand. If you do find a part number would you please post it here?
07-11-2020, 09:52 AM | #61 |
Old member
Will do sir!
