Old 05-31-2017, 11:27 PM   #1
svr
svr's Avatar
57 Short Box 235 5sp C4
Hello all, at Ogre's suggestion i decided I better start a build thread. First a little about me, old guy upper 60's, haven't done much of this kind of stuff since before i got married long time ago. Marriage, kids and business took all my time for all those years.
Now for the current project, my sons friend had done a lot of take apart and had started the body work enough you could see it wasn't near as bad as some of you guys start with but needed more. Was a running basket case, cab without doors that ran and got on my trailer. Heres a poor pic the day i drove it off the trailer into my shop.
svr is offline   Reply With Quote
Old 05-31-2017, 11:36 PM   #2
Az. Hank
Az. Hank's Avatar
Re: 57 Short Box 235 5sp C4
Welcome aboard
What are your plans for it?
My 55 Build 55 C-4
Az. Hank is offline   Reply With Quote
Old 06-01-2017, 12:34 AM   #3
svr
svr's Avatar
Wasnt sure just where i wanted to go the project but knew it needed cab corners, lower hinge pockets ect. Pretty regular stuff. The old 235 ran pretty good, you could see head had been off and probably redone at some point as the paint was gone on it only, probably at least a valve job had been done and maybe more hard to tell, good oil pressure, started easy cold, not hardly any smoke, decided to keep it, and add a T5. Old stock rear end had a lot of slop when i turned the yoke back and forth, pinion leaked and wheel seals leaked. I found a ford 9" from a early 70's pickup and plan A was to switch them and go with stock leaf springs and eventually give the front end a mustang II front suspension. Plan A wasnt a bad plan but being a guy that just cant leave pretty good alone I really wasnt happy with plan A. Watching the builds on the forum provided a lot of ideas and things to think about. Did I tell you my body work skills suck? I struggled along as I found more things here and there on the body to fix. Continued working on the cab, couldn't find a place to stop and before long interior was stripped, fuel tank, wireing and all, no turning back now. Sorry i'm not very good at stopping and takeing pics. Some time dureing the cold snowy winter reading build threads here and everywhere i could find them. The C4 builds really intrigued me, but had kind of pushed it out of my mind as being to much work and money. Then craigs list popped up with a complete rear suspension for a $100. Advertised as a 44 from an '87 stick shift car, next day i braved a snow storm to go see it, turned out to be a 36 from a '85 car, but for a franklin i brought it home and it was game on.
Old 06-01-2017, 12:13 PM   #4
Kim57
Kim57's Avatar
Welcome.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-02-2017, 12:48 AM   #5
svr
svr's Avatar
Guess i better add to my build thread and at least get a little more current.
After the C4 rear was found i went on the hunt for a front suspension, found 1 from an '88 so now I had the start of what i wanted. So next was to pull. The cab off and strip the frame of all unneeded parts and miserable rivets, was kinda crusty so off to a sand blaster to clean it up. looked at different methods and kits to mount both front and rear and decided to try and build my own mounts. With the help from several members here, a few do overs i got both front and rear mounted.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
Old 06-02-2017, 12:53 AM   #6
svr
svr's Avatar
Some more
Old 06-02-2017, 10:54 AM   #7
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 06-03-2017, 12:31 AM   #8
BIGglaSS
BIGglaSS's Avatar
You're off to a good start!
BIGglaSS is offline   Reply With Quote
Old 06-03-2017, 03:37 AM   #9
Daze57
Daze57's Avatar
lookin good
Daze57 is offline   Reply With Quote
Old 06-03-2017, 09:34 AM   #10
yossarian19
Very cool.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 06-03-2017, 10:07 AM   #11
FAKKY
Nice.
Subscribed.
FAKKY is offline   Reply With Quote
Old 06-04-2017, 11:38 PM   #12
svr
svr's Avatar
Guess i better continue the saga, the old 235 was crusty, greasy, and dirty. After much scraping, brushing, brake clean, and more cleaning i gave it a paint job, wish i would have had a little more paint at the time, seems a little thin inplaces now. Sants Clause brought a few goodies to bolt on. I made brackets for the alternator and PS pump, plumbed hot water to the intake maniflod. Made spacers for the carb tops so my air cleaners would clear and carb linkage to fit.
Old 06-04-2017, 11:39 PM   #13
svr
svr's Avatar
Another
Old 06-04-2017, 11:44 PM   #14
svr
svr's Avatar
Next came setting motor in to make sure everything will clear
Old 06-05-2017, 08:35 AM   #15
Kim57
Kim57's Avatar
Engine looks real nice.
Kim
My build thread
Old 06-05-2017, 10:57 PM   #16
svr
svr's Avatar
Not sure what your R&P looks like, mine has 2 rivet kind of fastners that held the steel tube to the cast aluminum about in the middle. I undid the lines and teased out the rivets with a hammer and chisel, screw driver, vice grips and what ever was handy at the time. They screw in with very coarse thread, about a quarter turn and the come out. Then I turned the steel tube with a pipe wrench to where I thought it would clear, redrilled the holes in the aluminum side and hammered the rivet screw deals back in. Then I massaged the original lines to where they would hook back up.
Old 06-08-2017, 01:18 PM   #17
akdg87
akdg87's Avatar
thanks, mine looks about the same, ill pick one up and give it a try.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 06-06-2017, 09:24 AM   #18
jjzepplin
jjzepplin's Avatar
Very nice!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-07-2017, 11:57 PM   #19
svr
svr's Avatar
A little more on the mounts i made for the rear suspension, plan is to use theoriginal leaf spring, some say they ride kinda hard, will take my chances. The wish bone mount and the pinion mount were pretty straight forward, dog bone mounts were a little tougher to make simple and look good.
Old 06-08-2017, 12:01 AM   #20
svr
svr's Avatar
Another
Old 06-08-2017, 12:03 AM   #21
svr
svr's Avatar
Side view with shock mounts, i created a small pile of scrap iron makeing these, several different versions i didnt like before i settled on these.
Old 06-08-2017, 12:14 AM   #22
svr
svr's Avatar
Next detail was i needed to mount an oil filter, original was a cartridge filter that hung on the intake manifold. I wanted to go to a spinon filter, always hated the cartridge ones. The 235 of my vintage is not a full flow fiter system its a bypass system so special considerations were needed. So off to the Inet to do the research, Inliners, Tom Langdon, Deves Tech all helped to figure out what was needed, anybody interested drop me a line, i think i have it right. Made a bracket and found a place to mount it so it is accessable and out of the way. Bent a couple lines and made the proper oriface.
Old 06-08-2017, 12:31 AM   #23
Dan in Pasadena
Dan in Pasadena's Avatar
SVR - Everything looks great!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-08-2017, 02:21 PM   #24
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 06-13-2017, 10:59 PM   #25
svr
svr's Avatar
One of the things I wanted to figure out before I mounted the cab was the brake master cylinder. Original plan was for a vacume boost master to operate the C4 brakes. I wanted to use the original pedal and after looking at several 7-8" boosters advertised as useing the original pedal, i was haveing trouble convincing myself the small booster with the limited vacume of my 235 would end in a happy situation. i decided a hydroboost system would be the best alternative. More research, reading, help from members here and a few trips to a couple of junk yards I came up with a mustang cobra hydroboost as one that should work. I wanted a remote reservoir and the plastic one it came with would come off pretty easy. I needed to make some fittings to accept lines from the master to the reservoir. A little measureing and lathe work I came up with these.
