04-17-2008, 12:08 AM | #26 |
Re: The LS1 swap headers are done!!!!
04-17-2008, 01:35 AM | #27 |
Ordered mine today!!
04-27-2008, 05:45 PM | #28 |
www.73-87chevytrucks.com
Jamie, check your PM's. I have some feedback on these for the 73-87's. I will be sending you the pics in an email.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
04-27-2008, 06:08 PM | #29 |
Here's a part number for the plug wires:
MSD Connector wires 8.5mm 32819 $67
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-29-2008, 10:38 PM | #30 |
Do you think you could send me some info on these headers for the 73-87's too? I'm doing a 6.0l swap on my truck and trying to find some good headers.
04-29-2008, 10:43 PM | #31 |
Holy Horepower Batman!!!
That thing is awesome!
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
04-29-2008, 10:56 PM | #32 |
There is issues with the drivers side header, it won't fit our bodystyle.
04-29-2008, 11:05 PM | #33 | |
R/
04-29-2008, 11:05 PM | #34 |
04-29-2008, 11:29 PM | #35 |
I am still going to use Thorleys, just going to wait until the get them modified for 73-87's. There is just a clearance issue with the tube going over the top.
I am using standard S&P plates.
04-30-2008, 12:03 AM | #36 |
Yeah the Thorleys look great and Tri-y will deliver perfectly at the power band I've got, so I think I'll wait too.
04-30-2008, 04:28 AM | #37 |
Do you think the same problem would exist if using the ECE motor mounts?
04-30-2008, 05:22 AM | #38 | |
This is with ECE plates (almost 3" forward from normal) This is with S&P plates (where it is supposed to be) I am really wanting to move the engine back another 1" if I can, but I would settle with what I have.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 04-30-2008 at 05:23 AM. Reason: I answered that wrong... |
04-30-2008, 08:52 PM | #39 |
I'm currently working with another member to see if the headers work with the later body style with different mounts. I will keep you guys posted.
Jamie |
04-30-2008, 09:18 PM | #40 |
What mounts are they Jamie? I have had 3 different motor plates from 3 different sources, they are all the same as far as location goes. The only different one would be ECE motor mounts which move the engine WAY to far forward for a 73-87 bodystyle (see above pic)
05-01-2008, 12:59 AM | #41 | |
It pcmcobra and he is using the carshop plates. He is anticipating the same issues. We will know more early next week when he gets to try the headers on. Looks like its only one pipe on the d/s that is hitting the power brake booster. I know that the engine in the 67 I did seemed to be way foward as well. Anybody have a 73-87 with the ece or cpp mounts? |
05-01-2008, 01:24 AM | #42 |
If they are these plates, they are the same as everyone elses stuff.. Common 4 hole SBC mount with a LS 3 hole mount and common lower hole, spacing won't be any different.
http://carshop.carshopinc.com/produc.../86959/C/S2349 here is the comparison: Carshop: S&P:
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 05-01-2008 at 01:32 AM. Reason: apparently I was dislexic |
05-20-2008, 04:01 AM | #43 |
Ok,
I got the headers today, and I can verify I am having the same issue as capt, kaos. I am using the carshop plates, pretty much the same "standard" design as posted above. Drivers side is hitting firewall "protrusion, same exact as posted above. Passenger side seems fine:
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
05-20-2008, 04:04 AM | #44 |
[quote=pcmcobra;2729329]Ok,
I got the headers today, and I can verify I am having the same issue as capt, kaos. I am using the carshop plates, pretty much the same "standard" design as posted above. Drivers side is hitting firewall "protrusion, same exact as posted above. Passenger side seems fine: I wonder if the ECE mounts will give you more room? I know they will move the engine forward a couple of inches. Do yoyu have the room?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-20-2008 at 04:04 AM. |
05-20-2008, 04:10 AM | #45 |
Rob,
I am not sure. I could look it over and see, who's got some ece mounts for me to try?
05-20-2008, 04:23 AM | #46 |
Just measure 2" forward all the way around and see if anything hits, .
05-20-2008, 04:52 AM | #47 |
ouch, those ece mounts are $219...
I'd rather use the mounts I have. Even sent the tranny xmember off to get a little "work" done to it so the 80 will bolt up. Hopefully we can get this figured out.
05-20-2008, 05:05 AM | #48 |
Nice,i plan to upgrade to a LS1 later!!
I need some headers for my 283 v8 Can u(beat) give me a better price than $275?
www.gkautospa.com Like A Rock! http://67-72chevytrucks.com/vboard/s...d.php?t=397153 Last edited by GKsport67; 05-20-2008 at 05:51 AM. |
05-20-2008, 05:09 AM | #49 |
You could always try this........................
05-20-2008, 05:17 AM | #50 |
lol@rob...
I have not gotten to that point yet...but I do have a bucket full of BFH's for stress relief, or persuasion...
